When I try to open the Python window AGP crashes. If I click on the Analysis tab it says it's creating the Geoprocessing Cache and then crashes. Any Ideas?
.... Version 2.3.3 ...
My guess would be that there is some kind of conflict with Python paths on the machine, or maybe Conda, can't be sure.
Did you have other installs of Python and/or Anaconda before installing Pro?
One thing you might check is if you have a Python path in your system's PATH environment variable.
From the Start button, search for Environment Variables
Check to see if you're pointing to a specific version of Python in the Path variable.
Hi Kory,
Thanks for your quick response.
I also have ArcMap 10.6.1 installed with it’s version of Python. No other installs of Python.
I can’t see any reference to Python in either the System Variables or my user variables.
Mitch
Can you send the .dmp file?
Go to C:\Users\<username>\AppData\Local\ESRI\ErrorReports and attach a few of the latest .dmp files from Pro crashing. The filename contains a date-time stamp:
Thank you.
The ErrorReports folder is empty.
