I'm in the process of configuring the config.js file to work with our SDE data. All was fine until I try to configure the return results in the Activity search, to show in the bottom pane. I can't seem to find an area in the config.js file to set the fields to show on the return results.It doesn't even return the park name that I have set in the info popup section. Does anyone know where to set these values?
