I know this may sound simple but it matters how you add the layers in ArcGIS Mobile 10.2 Examples:1) In ArcMap you can create one mxd with all 4 layers in order on the TOC:Points on top ofLines on top ofPolygon on top ofImagery (base)Then create a service and put it in ArcGIS Mobile 10.2) If you are using Mobile Project Center the same idea applies there.Imagery service is added first thenPolygon service thenLines service thenPoints added last.This way your layers will be in the proper order when you use them in ArcGIS Mobile 10.I hope this helps.
Sorry but now I have lost in terms of what you want.Are you using the Windows Tablet (out-of-the-box-solution)?Do you have an ArcGIS Server?The points and lines layers are operational layer correct?Did you create and mxd and then publish it to the arcgis server?I know you want to use the Toolbox in ArcMap to make the map cache but you can do the same in the application and use that and deploy it to all computers.Sorry for all the questions just trying to understand what you need.
