Hello,I have been trying to combine the "LegendBasic" code with "FeatureLayer - show InfoWindow on mouseOver" code and have come up with what is below. I have a problem in line 96 it says "the prefix 'mx' for element 'mx:TextArea" is not bound, and I am lost in how to solve it.Thank you 🙂Titoqan
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
              xmlns:s="library://ns.adobe.com/flex/spark"
              xmlns:esri="http://www.esri.com/2008/ags"
              pageTitle="Legend Component">
       This sample shows how to use the Legend component to build a legend that displays some or all of the layers in the map.
       To create a new legend component specify the map to be displayed.
       Optionally you can provide a list of layers to display in the legend.
       If no layers are specified then all the layers will display in the legend.
       The respectCurrentMapScale property, if set to true (default) will force the legend component to only display layers that are visible in the current map scale.
   <s:layout>
       <s:HorizontalLayout gap="0"/>
   </s:layout>
   <esri:Legend id="myLegend"
                width="250" height="100%"
                layers="{[ legendLayer ]}"
                map="{myMap}"
                respectCurrentMapScale="true"/>
<fx:Script>
 <![CDATA[
  import com.esri.ags.Graphic;
  import com.esri.ags.SpatialReference;
  import com.esri.ags.events.GraphicEvent;
  import com.esri.ags.geometry.Extent;
 Â
  protected function fLayer_graphicAddHandler(event:GraphicEvent):void
   event.graphic.addEventListener(MouseEvent.MOUSE_OVER, onMouseOverHandler);
   event.graphic.addEventListener(MouseEvent.MOUSE_OUT, onMouseOutHandler);
 Â
  private function onMouseOverHandler(event:MouseEvent):void
   var gr:Graphic = Graphic(event.target);
   gr.symbol = mouseOverSymbol;
   myTextArea.htmlText = "<b>2000 County FIPS: </b>" + gr.attributes.ba_cb_cty.FPS.toString() + "\n"
    + "<b>County Name: </b>" + gr.attributes.Name.toString() + "\n"
    + "<b>: </b>" + gr.attributes.MALES + "\n"
   myMap.infoWindow.label = gr.attributes.NAME;
   myMap.infoWindow.closeButtonVisible = false;
   myMap.infoWindow.show(myMap.toMapFromStage(event.stageX, event.stageY));
 Â
  private function onMouseOutHandler(event:MouseEvent):void
   gr.symbol = defaultsym;
   myMap.infoWindow.hide();
 Â
  private function zoomToSouthCarolina():void
   var southCarolinaExtent:Extent = new Extent(-9294000, 3667000, -8739000, 4217000, new SpatialReference(102100));
   myMap.extent = southCarolinaExtent;
  Â
   // make sure the whole extent is visible
   if (!myMap.extent.contains(southCarolinaExtent))
    myMap.level--;
   Â
</fx:Script>
<fx:Style>
 @namespace esri "http://www.esri.com/2008/ags";
Â
 esri|InfoWindow
  content-background-alpha : 0;
  background-color : yellow;
  background-alpha : 0.8;
  border-style : solid;
</fx:Style>
<fx:Declarations>
 <esri:SimpleFillSymbol id="mouseOverSymbol" alpha="0.5">
  <esri:SimpleLineSymbol width="0" color="0xFF0000"/>
 </esri:SimpleFillSymbol>
 <esri:SimpleFillSymbol id="defaultsym" alpha="0.2">
  <esri:SimpleLineSymbol width="1" color="0xEEEEEE"/>
</fx:Declarations>
   <esri:Map id="myMap">
 <esri:infoWindowContent>
  <mx:TextArea id="myTextArea" width="250" height="95">
  </mx:TextArea>
 </esri:infoWindowContent>
       <esri:ArcGISTiledMapServiceLayer id="baseLayer" url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/>
       <esri:ArcGISDynamicMapServiceLayer id="legendLayer" name="Projected Population in 2025"
                                          url="http://204.236.161.112/ArcGIS/rest/services/CountyCombined-added/MapServer/4" alpha=".7"/>
 <esri:extent>
  <esri:Extent xmin="-11866000" ymin="-284000" xmax="-7977000" ymax="2919000">
   <esri:SpatialReference wkid="102100"/>
  </esri:Extent>
 </esri:extent>
</esri:Map>
</s:Application>PS. Eventually, I am trying to dynamically show the correct legend when a layer is turned on, as well as the correct mouseovers.http://204.236.161.112/_CBWS03.htmlThank you again
