Hello everyone,
We are looking to export the usage of applications on our AGO site - not credit usage but actual views and associated analytics. It appears you can only view this data and not export it in any way. It would be great if we could somehow export the data via python. Attached image shows what we are after. Thanks!
Hi Ian,
I believe this is not available yet, but is something that has been looked at, from what I can tell. Take a look at this Idea (and consider voting it Up):
Access Raw (Rest API) data from AGOL Feature Service usage statistics
There are also many other Ideas with similar thoughts that would be wise to vote up. Also, this thread may be best placed in the ArcGIS Online space.
(another idea that may be worth voting up: https://community.esri.com/ideas/5439 )
Thanks I just voted that idea up. Not sure this thread will go anywhere in the AGO space but mods are welcome to move it.
I am convinced that this and this will do as you ask, but would require some python tinkering that is beyond my skill level. I too, am looking for the same thing. I have hundreds of hosted feature services, and we need a more automated/technical way of getting those into a spreadsheet so we can globally look at service usage and make management decisions on how or when we update data. Having to click the usage button on 400 different item description pages then screen-shooting the graph does not meet that need. Surprised with such a well-documented REST API, that Esri has not included this basic requirement.
The following, albeit a bit bulky, will read from a list of hosted feature services and create a csv for each with date and service calls per date. You can change the date range by changing the epoch date stamps.
<SPAN class="keyword token">import</SPAN> csv <SPAN class="keyword token">import</SPAN> urllib <SPAN class="keyword token">import</SPAN> urllib2 <SPAN class="keyword token">import</SPAN> json <SPAN class="keyword token">import</SPAN> datetime <SPAN class="comment token"># need to get a token</SPAN> tokenURL <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>'</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fwww.arcgis.com%2Fsharing%2Frest%2FgenerateToken" target="_blank">https://www.arcgis.com/sharing/rest/generateToken</A><SPAN>'</SPAN></SPAN> params <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="string token">'f'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'pjson'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'username'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'username'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'password'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'password'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'referer'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>'</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fwww.arcgis.com" target="_blank">https://www.arcgis.com</A><SPAN>'</SPAN></SPAN><SPAN class="punctuation token">}</SPAN> req <SPAN class="operator token">=</SPAN> urllib2<SPAN class="punctuation token">.</SPAN>Request<SPAN class="punctuation token">(</SPAN>tokenURL<SPAN class="punctuation token">,</SPAN> urllib<SPAN class="punctuation token">.</SPAN>urlencode<SPAN class="punctuation token">(</SPAN>params<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> response <SPAN class="operator token">=</SPAN> urllib2<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>req<SPAN class="punctuation token">)</SPAN> data <SPAN class="operator token">=</SPAN> json<SPAN class="punctuation token">.</SPAN>load<SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> token <SPAN class="operator token">=</SPAN> data<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'token'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="comment token"># read list of AGOL service names</SPAN> readCSV <SPAN class="operator token">=</SPAN> list<SPAN class="punctuation token">(</SPAN>csv<SPAN class="punctuation token">.</SPAN>reader<SPAN class="punctuation token">(</SPAN>open<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'service.csv'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> names <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> readCSV<SPAN class="punctuation token">:</SPAN> name <SPAN class="operator token">=</SPAN> row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="comment token">#generate url list of up to 7 api calls</SPAN> <SPAN class="comment token">#Esri truncates usage stats into blocks of approx. 52 days</SPAN> <SPAN class="comment token">#Making a single url call for entire year will fail</SPAN> <SPAN class="comment token">#replace org with your org name and org_id with your org id</SPAN> url1 <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>'</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Forg.maps.arcgis.com%2Fsharing%2Frest%2Fportals%2Forg_id%2Fusage%3Ff%3Djson%26startTime%3D1451624400000%26endTime%3D1456808400000%26period%3D1d%26vars%3Dnum%26groupby%3Dname%26etype%3Dsvcusg%26name%3D" target="_blank">https://org.maps.arcgis.com/sharing/rest/portals/org_id/usage?f=json&startTime=1451624400000&endTime=1456808400000&period=1d&vars=num&groupby=name&etype=svcusg&name=</A><SPAN>'</SPAN></SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'&stype=features&token='</SPAN><SPAN class="operator token">+</SPAN>token url2 <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>'</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Forg.maps.arcgis.com%2Fsharing%2Frest%2Fportals%2Forg_id%2Fusage%3Ff%3Djson%26startTime%3D1456808400000%26endTime%3D1461988800000%26period%3D1d%26vars%3Dnum%26groupby%3Dname%26etype%3Dsvcusg%26name%3D" target="_blank">https://org.maps.arcgis.com/sharing/rest/portals/org_id/usage?f=json&startTime=1456808400000&endTime=1461988800000&period=1d&vars=num&groupby=name&etype=svcusg&name=</A><SPAN>'</SPAN></SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'&stype=features&token='</SPAN><SPAN class="operator token">+</SPAN>token url3 <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>'</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Forg.maps.arcgis.com%2Fsharing%2Frest%2Fportals%2Forg_id%2Fusage%3Ff%3Djson%26startTime%3D1461988800000%26endTime%3D1467172800000%26period%3D1d%26vars%3Dnum%26groupby%3Dname%26etype%3Dsvcusg%26name%3D" target="_blank">https://org.maps.arcgis.com/sharing/rest/portals/org_id/usage?f=json&startTime=1461988800000&endTime=1467172800000&period=1d&vars=num&groupby=name&etype=svcusg&name=</A><SPAN>'</SPAN></SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'&stype=features&token='</SPAN><SPAN class="operator token">+</SPAN>token url4 <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>'</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Forg.maps.arcgis.com%2Fsharing%2Frest%2Fportals%2Forg_id%2Fusage%3Ff%3Djson%26startTime%3D1467172800000%26endTime%3D1472356800000%26period%3D1d%26vars%3Dnum%26groupby%3Dname%26etype%3Dsvcusg%26name%3D" target="_blank">https://org.maps.arcgis.com/sharing/rest/portals/org_id/usage?f=json&startTime=1467172800000&endTime=1472356800000&period=1d&vars=num&groupby=name&etype=svcusg&name=</A><SPAN>'</SPAN></SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'&stype=features&token='</SPAN><SPAN class="operator token">+</SPAN>token url5 <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>'</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Forg.maps.arcgis.com%2Fsharing%2Frest%2Fportals%2Forg_id%2Fusage%3Ff%3Djson%26startTime%3D1472356800000%26endTime%3D1477540800000%26period%3D1d%26vars%3Dnum%26groupby%3Dname%26etype%3Dsvcusg%26name%3D" target="_blank">https://org.maps.arcgis.com/sharing/rest/portals/org_id/usage?f=json&startTime=1472356800000&endTime=1477540800000&period=1d&vars=num&groupby=name&etype=svcusg&name=</A><SPAN>'</SPAN></SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'&stype=features&token='</SPAN><SPAN class="operator token">+</SPAN>token url6 <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>'</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Forg.maps.arcgis.com%2Fsharing%2Frest%2Fportals%2Forg_id%2Fusage%3Ff%3Djson%26startTime%3D1477540800000%26endTime%3D1482728400000%26period%3D1d%26vars%3Dnum%26groupby%3Dname%26etype%3Dsvcusg%26name%3D" target="_blank">https://org.maps.arcgis.com/sharing/rest/portals/org_id/usage?f=json&startTime=1477540800000&endTime=1482728400000&period=1d&vars=num&groupby=name&etype=svcusg&name=</A><SPAN>'</SPAN></SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'&stype=features&token='</SPAN><SPAN class="operator token">+</SPAN>token url7 <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>'</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Forg.maps.arcgis.com%2Fsharing%2Frest%2Fportals%2Forg_id%2Fusage%3Ff%3Djson%26startTime%3D1482728400000%26endTime%3D1483160400000%26period%3D1d%26vars%3Dnum%26groupby%3Dname%26etype%3Dsvcusg%26name%3D" target="_blank">https://org.maps.arcgis.com/sharing/rest/portals/org_id/usage?f=json&startTime=1482728400000&endTime=1483160400000&period=1d&vars=num&groupby=name&etype=svcusg&name=</A><SPAN>'</SPAN></SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'&stype=features&token='</SPAN><SPAN class="operator token">+</SPAN>token <SPAN class="comment token">#Make 7 url calls for year. Will fail if 7 calls and feature was posted mid-year</SPAN> <SPAN class="comment token">#so try blocks will keep trying less url calls</SPAN> <SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'Reading the usage statistics for '</SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">' for 2016....'</SPAN> filename <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'.csv'</SPAN> data <SPAN class="operator token">=</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url1<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url2<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url3<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url4<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url5<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url6<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url7<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'Writing '</SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>filename<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'....'</SPAN> <SPAN class="keyword token">with</SPAN> open<SPAN class="punctuation token">(</SPAN>filename<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'wb'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> output<SPAN class="punctuation token">:</SPAN> csv_writer <SPAN class="operator token">=</SPAN> csv<SPAN class="punctuation token">.</SPAN>writer<SPAN class="punctuation token">(</SPAN>output<SPAN class="punctuation token">)</SPAN> csv_writer<SPAN class="punctuation token">.</SPAN>writerow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'date'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> date<SPAN class="punctuation token">,</SPAN> count <SPAN class="keyword token">in</SPAN> data<SPAN class="punctuation token">:</SPAN> csv_writer<SPAN class="punctuation token">.</SPAN>writerow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>datetime<SPAN class="punctuation token">.</SPAN>datetime<SPAN class="punctuation token">.</SPAN>fromtimestamp<SPAN class="punctuation token">(</SPAN>int<SPAN class="punctuation token">(</SPAN>date<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">/</SPAN><SPAN class="number token">1e3</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> count<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">except</SPAN> Exception<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'Reading the usage statistics for '</SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">' for the last 313 days of 2016....'</SPAN> filename <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'.csv'</SPAN> data <SPAN class="operator token">=</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url2<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url3<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url4<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url5<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url6<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url7<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'Writing '</SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>filename<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'....'</SPAN> <SPAN class="keyword token">with</SPAN> open<SPAN class="punctuation token">(</SPAN>filename<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'wb'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> output<SPAN class="punctuation token">:</SPAN> csv_writer <SPAN class="operator token">=</SPAN> csv<SPAN class="punctuation token">.</SPAN>writer<SPAN class="punctuation token">(</SPAN>output<SPAN class="punctuation token">)</SPAN> csv_writer<SPAN class="punctuation token">.</SPAN>writerow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'date'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> date<SPAN class="punctuation token">,</SPAN> count <SPAN class="keyword token">in</SPAN> data<SPAN class="punctuation token">:</SPAN> csv_writer<SPAN class="punctuation token">.</SPAN>writerow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>datetime<SPAN class="punctuation token">.</SPAN>datetime<SPAN class="punctuation token">.</SPAN>fromtimestamp<SPAN class="punctuation token">(</SPAN>int<SPAN class="punctuation token">(</SPAN>date<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">/</SPAN><SPAN class="number token">1e3</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> count<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">except</SPAN> Exception<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'Reading the usage statistics for '</SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">' for the last 261 days of 2016....'</SPAN> filename <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'.csv'</SPAN> data <SPAN class="operator token">=</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url3<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url4<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url5<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url6<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url7<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'Writing '</SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>filename<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'....'</SPAN> <SPAN class="keyword token">with</SPAN> open<SPAN class="punctuation token">(</SPAN>filename<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'wb'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> output<SPAN class="punctuation token">:</SPAN> csv_writer <SPAN class="operator token">=</SPAN> csv<SPAN class="punctuation token">.</SPAN>writer<SPAN class="punctuation token">(</SPAN>output<SPAN class="punctuation token">)</SPAN> csv_writer<SPAN class="punctuation token">.</SPAN>writerow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'date'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> date<SPAN class="punctuation token">,</SPAN> count <SPAN class="keyword token">in</SPAN> data<SPAN class="punctuation token">:</SPAN> csv_writer<SPAN class="punctuation token">.</SPAN>writerow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>datetime<SPAN class="punctuation token">.</SPAN>datetime<SPAN class="punctuation token">.</SPAN>fromtimestamp<SPAN class="punctuation token">(</SPAN>int<SPAN class="punctuation token">(</SPAN>date<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">/</SPAN><SPAN class="number token">1e3</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> count<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">except</SPAN> Exception<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'Reading the usage statistics for '</SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">' for the last 209 days of 216....'</SPAN> filename <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'.csv'</SPAN> data <SPAN class="operator token">=</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url4<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url5<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url6<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url7<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'Writing '</SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>filename<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'....'</SPAN> <SPAN class="keyword token">with</SPAN> open<SPAN class="punctuation token">(</SPAN>filename<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'wb'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> output<SPAN class="punctuation token">:</SPAN> csv_writer <SPAN class="operator token">=</SPAN> csv<SPAN class="punctuation token">.</SPAN>writer<SPAN class="punctuation token">(</SPAN>output<SPAN class="punctuation token">)</SPAN> csv_writer<SPAN class="punctuation token">.</SPAN>writerow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'date'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> date<SPAN class="punctuation token">,</SPAN> count <SPAN class="keyword token">in</SPAN> data<SPAN class="punctuation token">:</SPAN> csv_writer<SPAN class="punctuation token">.</SPAN>writerow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>datetime<SPAN class="punctuation token">.</SPAN>datetime<SPAN class="punctuation token">.</SPAN>fromtimestamp<SPAN class="punctuation token">(</SPAN>int<SPAN class="punctuation token">(</SPAN>date<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">/</SPAN><SPAN class="number token">1e3</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> count<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">except</SPAN> Exception<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'Reading the usage statistics for '</SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">' for the last 157 days of 2016....'</SPAN> filename <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'.csv'</SPAN> data <SPAN class="operator token">=</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url5<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url6<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url7<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'Writing '</SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>filename<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'....'</SPAN> <SPAN class="keyword token">with</SPAN> open<SPAN class="punctuation token">(</SPAN>filename<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'wb'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> output<SPAN class="punctuation token">:</SPAN> csv_writer <SPAN class="operator token">=</SPAN> csv<SPAN class="punctuation token">.</SPAN>writer<SPAN class="punctuation token">(</SPAN>output<SPAN class="punctuation token">)</SPAN> csv_writer<SPAN class="punctuation token">.</SPAN>writerow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'date'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> date<SPAN class="punctuation token">,</SPAN> count <SPAN class="keyword token">in</SPAN> data<SPAN class="punctuation token">:</SPAN> csv_writer<SPAN class="punctuation token">.</SPAN>writerow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>datetime<SPAN class="punctuation token">.</SPAN>datetime<SPAN class="punctuation token">.</SPAN>fromtimestamp<SPAN class="punctuation token">(</SPAN>int<SPAN class="punctuation token">(</SPAN>date<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">/</SPAN><SPAN class="number token">1e3</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> count<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">except</SPAN> Exception<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'Reading the usage statistics for '</SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">' for the last 105 days of 2016....'</SPAN> filename <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'.csv'</SPAN> data <SPAN class="operator token">=</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url6<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> data <SPAN class="operator token">=</SPAN> data <SPAN class="operator token">+</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url7<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'Writing '</SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>filename<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'....'</SPAN> <SPAN class="keyword token">with</SPAN> open<SPAN class="punctuation token">(</SPAN>filename<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'wb'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> output<SPAN class="punctuation token">:</SPAN> csv_writer <SPAN class="operator token">=</SPAN> csv<SPAN class="punctuation token">.</SPAN>writer<SPAN class="punctuation token">(</SPAN>output<SPAN class="punctuation token">)</SPAN> csv_writer<SPAN class="punctuation token">.</SPAN>writerow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'date'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> date<SPAN class="punctuation token">,</SPAN> count <SPAN class="keyword token">in</SPAN> data<SPAN class="punctuation token">:</SPAN> csv_writer<SPAN class="punctuation token">.</SPAN>writerow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>datetime<SPAN class="punctuation token">.</SPAN>datetime<SPAN class="punctuation token">.</SPAN>fromtimestamp<SPAN class="punctuation token">(</SPAN>int<SPAN class="punctuation token">(</SPAN>date<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">/</SPAN><SPAN class="number token">1e3</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> count<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">except</SPAN> Exception<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'Reading the usage statistics for '</SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">' for the last 53 days of 2016....'</SPAN> filename <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'.csv'</SPAN> data <SPAN class="operator token">=</SPAN> json<SPAN class="punctuation token">.</SPAN>loads<SPAN class="punctuation token">(</SPAN>urllib<SPAN class="punctuation token">.</SPAN>urlopen<SPAN class="punctuation token">(</SPAN>url7<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>read<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'data'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'num'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'Writing '</SPAN><SPAN class="operator token">+</SPAN><SPAN class="punctuation token">(</SPAN>filename<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">+</SPAN><SPAN class="string token">'....'</SPAN> <SPAN class="keyword token">with</SPAN> open<SPAN class="punctuation token">(</SPAN>filename<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'wb'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> output<SPAN class="punctuation token">:</SPAN> csv_writer <SPAN class="operator token">=</SPAN> csv<SPAN class="punctuation token">.</SPAN>writer<SPAN class="punctuation token">(</SPAN>output<SPAN class="punctuation token">)</SPAN> csv_writer<SPAN class="punctuation token">.</SPAN>writerow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'date'</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">(</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">for</SPAN> date<SPAN class="punctuation token">,</SPAN> count <SPAN class="keyword token">in</SPAN> data<SPAN class="punctuation token">:</SPAN> csv_writer<SPAN class="punctuation token">.</SPAN>writerow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>datetime<SPAN class="punctuation token">.</SPAN>datetime<SPAN class="punctuation token">.</SPAN>fromtimestamp<SPAN class="punctuation token">(</SPAN>int<SPAN class="punctuation token">(</SPAN>date<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">/</SPAN><SPAN class="number token">1e3</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> count<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">except</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">'No usage statistics available too short time range'</SPAN> <SPAN class="keyword token">pass</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
