//create array of attributes var items = dojo.map(results, function (result) { var graphic = result.feature; graphic.setSymbol(symbol); map.graphics.add(graphic); return dojo.clone(result.feature.attributes); }); //Create data object to be used in store var data = { identifier: "OBJECTID", //This field needs to have unique values label: "ID", //Name field for display. Not pertinent to a grid but may be used elsewhere. items: items }; //Create data store and bind to grid. store = new dojo.data.ItemFileReadStore({ data: data }); var grid = dijit.byId('gridCorners'); grid.setStore(store);
Hi Jay, Here are some samples that has the functionality that you are interested in Buffer and Query https://developers.arcgis.com/javascript/jssamples/query_buffer.html Click on the record in the datagrid, and the appropriate feature gets zoomed and highlighted http://developers.arcgis.com/javascript/samples/fl_zoomgrid/ I hope these samples would give you an idea to move forward. Thanks, Suba
//Select features within the buffered polygon. To do so we'll create a query to use the buffer graphic //as the selection geometry. var query = new Query(); query.geometry = bufferGeometry; featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(results){ var totalPopulation = sumPopulation(results); var r = ""; r = "<b>The total Census Block population within the buffer is <i>" + totalPopulation + "</i>.</b>"; dom.byId('messages').innerHTML = r; var items = dojo.map(featureSet.features,function(feature){ return feature.attributes; }); var data = { identifier:"ObjectID", items:items}; store = new dojo.data.ItemFileReadStore({data:data}); grid.setStore(store); grid.setSortIndex(1,"true"); //sort on the state name });
<div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'left'" style="width:255px"> <table data-dojo-type="dojox.grid.DataGrid" jsid="grid" id="grid" selectionMode="none"> <thead> <tr> <th field="ObjectID" formatter="makeZoomButton" width="25px"> <img alt="+" src="images/flag.png"/> </th> <th field="STATE_NAME" width="100px">State</th> <th field="POP2000" width="100px">Population</th> </tr> </thead> </table> </div>
//Select features within the buffered polygon. To do so we'll create a query to use the buffer graphic //as the selection geometry. var query = new Query(); query.geometry = bufferGeometry; featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(results){ var totalPopulation = sumPopulation(results); var r = ""; r = "<b>The total Census Block population within the buffer is <i>" + totalPopulation + "</i>.</b>"; dom.byId('messages').innerHTML = r; var data = array.map(results.features, function (feature) { return { // property names used here match those used when creating the dgrid "id": feature.attributes[window.outFields[0]], "Name": feature.attributes[window.outFields[1]], "Type": feature.attributes[window.outFields[2]] }; }); var memStore = new dojo.store.Memory({ data: data }); window.grid.set("store", memStore); }); }); function sumPopulation(features) { var popTotal = 0; for (var x = 0; x < features.length; x++) { popTotal = popTotal + features.attributes['Number']; } return popTotal; }
<div id="mainWindow" style="width:100%; height:100%;"> <div style="background-color:#EEEEEE;height:100%;width:300px;float:left;"> <table jsid="grid" id="grid"> <thead> <tr> <th field="ObjectID" formatter="makeZoomButton" width="25px"> <img alt="+" src="images/flag.png"/> </th> <th field="NAME" width="100px">WMA Name</th> <th field="TYPE" width="100px">Region</th> </tr> </thead> </table> </div> <div id="mapDiv" style="background-color:#EEEEEE;height:100%;width:auto;float:left;"></div> </div>
dojo.connect(dijit.byId('gridCorners'), "onRowClick", onRowClickHandler);
//Zoom to the parcel when the user clicks a row function onRowClickHandler(evt) { map.getLayer(selectedCulvertsID).clear; var clickedTaxLotId = dijit.byId('gridCorners').getItem(evt.rowIndex).OBJECTID; var selectedTaxLot; var symbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_X, 15, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 0, 0, .01])); dojo.forEach(map.graphics.graphics, function (graphic) { if ((graphic.attributes) && graphic.attributes.OBJECTID === clickedTaxLotId[0]) { selectedTaxLot = graphic; return; } }); AddGraphic(map.getLayer(selectedCulvertsID), symbol, selectedTaxLot.geometry); var culvertGeometry = selectedTaxLot.geometry; var factor = 1; //some factor for converting point to extent var culvertExtent = new esri.geometry.Extent(culvertGeometry.x - factor, culvertGeometry.y - factor, culvertGeometry.x + factor, culvertGeometry.y + factor, culvertGeometry.SpatialReference); map.setExtent(culvertExtent.expand(80)); }
<body class="tundra"> <div id="grid"></div> <div id="mapDiv"> <div id="info"></div> </div> </body>
var map; require([ "esri/map", "esri/layers/FeatureLayer", "esri/tasks/query", "esri/tasks/QueryTask", "esri/tasks/GeometryService", "esri/tasks/BufferParameters", "esri/graphic", "esri/InfoTemplate", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/TimeExtent", "dojo/number", "dojo/date/locale", "dojo/_base/array", "dojo/store/Memory", "dgrid/OnDemandGrid", "esri/renderers/SimpleRenderer", "esri/lang", "dojo/dom-style", "dijit/TooltipDialog", "dijit/popup", "esri/config", "dojo/_base/Color", "dojo/dom", "dojo/domReady" ], function( Map, FeatureLayer, Query, QueryTask, GeometryService, BufferParameters, Graphic, InfoTemplate, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, TimeExtent, number, locale, arrayUtils, Memory, OnDemandGrid, SimpleRenderer, esriLang, domStyle, TooltipDialog, dijitPopup, esriConfig, Color, dom ) { // create a dgrid var sortAttr = [{ attribute: "SITENAME", descending: true }]; grid = new OnDemandGrid({ store: Memory({ idProperty: "SITENAME" }), columns:{ NAME: "SiteNames", REGION: "Regions", }, sort: sortAttr }, "grid"); esri.config.defaults.io.proxyUrl = "https://fwisweb1.dgif.virginia.gov/proxypage_net/proxy.ashx"; map = new Map("mapDiv", { basemap: "streets", center: [-77.4329, 37.5410], zoom: 7, slider: false }); var featureLayer = new FeatureLayer("https://SOMESERVER/arcgis/rest/services/Test/RampTEST/FeatureServer/0", { mode: FeatureLayer.MODE_SELECTION, outFields: ['*'] }); map.infoWindow.resize(245,125); dialog = new TooltipDialog({ id: "tooltipDialog", style: "position: absolute; width: 250px; font: normal normal normal 10pt Helvetica;z-index:100" }); dialog.startup(); // selection symbol used to draw the selected census block points within the buffer polygon var point = new SimpleMarkerSymbol( SimpleMarkerSymbol.STYLE_CIRCLE, 25, new SimpleLineSymbol( SimpleLineSymbol.STYLE_NULL, new Color([137, 214, 171, 0.9]), 1 ), new Color([137, 214, 171, 0.5]) ); // Blue new Color([160, 177, 232, 0.5]) // Green new Color([137, 214, 171, 0.9]), //close the dialog when the mouse leaves the highlight graphic map.on("load", function(){ map.graphics.enableMouseEvents(); map.graphics.on("mouse-out", closeDialog); }); //listen for when the onMouseOver event fires on the countiesGraphicsLayer //when fired, create a new graphic with the geometry from the event.graphic and add it to the maps graphics layer featureLayer.on("mouse-over", function(evt){ var t = "<b>${SITENAME}</b><hr><b>Region: </b>${REGION}<br>"; var content = esriLang.substitute(evt.graphic.attributes,t); var highlightGraphic = new Graphic(evt.graphic.geometry,point); map.graphics.add(highlightGraphic); dialog.setContent(content); domStyle.set(dialog.domNode, "opacity", 0.85); dijitPopup.open({ popup: dialog, x: evt.pageX, y: evt.pageY }); }); function closeDialog() { map.graphics.clear(); dijitPopup.close(dialog); } // selection symbol used to draw the selected census block points within the buffer polygon var symbol = new SimpleMarkerSymbol( SimpleMarkerSymbol.STYLE_CIRCLE, 12, new SimpleLineSymbol( SimpleLineSymbol.STYLE_NULL, new Color([247, 34, 101, 0.9]), 1 ), new Color([207, 34, 171, 0.5]) ); featureLayer.setSelectionSymbol(symbol); // change cursor to indicate features are click-able featureLayer.on("mouse-over", function () { map.setMapCursor("pointer"); }); featureLayer.on("mouse-out", function () { map.setMapCursor("default"); }); // Add the Feature Layer To Map map.addLayer(featureLayer); // geometry service that will be used to perform the buffer var geometryService = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"); //when the map is clicked create a buffer around the click point of the specified distance. map.on("click", function(evt){ //define input buffer parameters var params = new BufferParameters(); params.geometries = [ evt.mapPoint ]; params.distances = [ 40 ]; params.unit = GeometryService.UNIT_STATUTE_MILE; geometryService.buffer(params); }); geometryService.on("buffer-complete", function(result){ map.graphics.clear(); // draw the buffer geometry on the map as a map graphic var symbol = new SimpleFillSymbol( SimpleFillSymbol.STYLE_NULL, new SimpleLineSymbol( SimpleLineSymbol.STYLE_SHORTDASHDOTDOT, new Color([105,105,105]), 2 ),new Color([255,255,0,0.25]) ); var bufferGeometry = result.geometries[0] var graphic = new Graphic(bufferGeometry, symbol); map.graphics.add(graphic); //Select features within the buffered polygon. To do so we'll create a query to use the buffer graphic //as the selection geometry. var query = new Query(); query.geometry = bufferGeometry; featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(results){ var totalPopulation = sumPopulation(results); var r = ""; r = "<b>The total Census Block population within the buffer is <i>" + totalPopulation + "</i>.</b>"; dom.byId('messages').innerHTML = r; }); // Query for the records with the given object IDs and populate the grid featureLayer.queryFeatures(query, function (featureSet) { updateGrid(featureSet); }); }); function updateGrid(featureSet) { var data = arrayUtils.map(featureSet.features, function (entry, i) { return { NAME: entry.attributes.SITENAME, REGION: entry.attributes.REGION }; }); grid.store.setData(data); grid.refresh(); } });
html, body, #mapDiv { padding: 0; margin: 0; height: 100%; } #messages{ background-color: #fff; box-shadow: 0 0 5px #888; font-size: 1.1em; max-width: 15em; padding: 0.5em; position: absolute; right: 20px; top: 20px; z-index: 40; } #grid { height: 336px; width: 100%; } .field-name { width: 100px; font-size: .80em; font-weight: normal; } .field-magnitude { width: 50px; font-size: .80em; font-weight: normal; } .field-deaths { width: 70px; font-size: .80em; font-weight: normal; } .field-date { width: 70px; font-size: .80em; font-weight: normal; } #grid .dgrid-row-odd { background: #F2F5F9; } #info { background: #fff; box-shadow: 0 0 5px #888; left: 1em; padding: 0.5em; position: absolute; top: 1em; z-index: 40; }
