Hi folksI want to update the value of a textbox (i.e. EDIT field) called "txtCOMMON" based on the value of a Combobox called "cboSCIENTIFIC".The Combobox is populated by a dbf file called "ListSpecies.dbf", with two fields, [SCIENTIFIC] amd [COMMON].I want to attach a function to the onselchange event of "cboSCIENTIFIC" which looks up the corresponding COMMON name in the dbf file, i.e. return [COMMON] where [SCIENTIFIC]=cboScientific.value.I am making no headway and would appreciate assistance.RegardsOisink
Sub ShowCommonName() Dim objControl, objPage, objRecords, ScientificName Bookmark Set objPage = ThisEvent.Object.Parent 'Get cboScientific value ScientificName = ThisEvent.Object.Value 'Open the dbf Set objRecords = Application.CreateAppObject("Recordset") Call objRecords.open("C:\ListSpecies.dbf",1) 'Find the matching item BookMark = rsAI.Find("[SCIENTIFIC]=""" & ScientificName & """") 'Check for a match If BookMark = 0 Then 'No match, return the default value 'TODO: is there a valid default value objPage.Controls("txtCOMMON").Value = "" Exit Sub Else objPage.Controls("txtCOMMON").Value = objRecords.Fields("COMMON").Value End If End Sub
Try something like this:set objFORM = layer.Forms("EDITFORM").controlsset objRecords = Application.CreateAppObject("Recordset")call objRecords.open("c:\ListSpecies.dbf",1)objrecords.movefirst While not objrecords.EOF if objrecords.fields.item("SCIENTIFIC").value = cboSCIENTIFIC.value then objForm("txtCOMMON").value = objrecords.fields.item("COMMON").value end if objWriteRecords.movenext Wendyou may need objFORM("txtCOMMON").setfocus in the if then else statement and use objFORM("txtCOMMON").text = "......Good luck bro.
Hi citrusmosquito I'm interested in your comment: [INDENT][/INDENT]"Search "recordset" in the help index for more help"I have only ArcPad 7.1. No ArcBuilder/ArcStudio etc. I've never been able to find any help or porgramming reference relating to the API, not even an Object Model. I'm probably being dumb, but can you point me in the right direction?ThanksOisin
