Hi Matt,The FocalMean command you're familiar with is not available in the new raster calculator. The documentation you pointed to is wrong and I will submit a defect to have it changed. To accomplish this task you need to use FocalStatistics with the mean statistic type within your Con statement. It should look like this:**unspecified**= Con(IsNull("point2ras"),FocalStatistics("point2ras",NbrRectangle(3,3),"MEAN"),"point2ras")Where **unspecified** is my output name and i'm using a 3 x 3 rectangular neighborhood.You may find this link helpful as it discusses differences between 9.x and 10.http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Comparing_Map_Algebra_between_9_x_and_10/00p600000018000000/What is Map Algebra (in 10)http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/What_is_Map_Algebra/00p600000002000000/Let me know if this helps.Regards,Eric
Thanks Dan. I checked with the Arc10 Resource Center (URL: http://help.arcgis.com/EN/ArcGISDesktop/10.0/Help/00q8/00q80000006m000000.htm) for help with the syntax and case but unfortunately it's still not working: Con(IsNull([point2ras]), FOCALMEAN ([point2ras] , RECTANGLE , 3 , 3, data), [point2ras]) When I run the expression with that structure, Spatial Analyst returns an error saying that the name of the input raster is not defined. I inserted "" around the layer name, re-ran it, and got a different error ['expected a raster or layer name']. I've attached a screen-capture of the error messages, for reference. Any other suggestions? Thanks, Matt
Hi Jamal,I reviewed your screenshot and you are specifying FOCALMEAN which is not a command in map algebra at 10.0. Please review my earlier post wherein I provide the syntax to use at 10.0. i.e. FocalStatisticsRegards,Eric
Jamal,Your expression is using �??wt�?� but your layer name is �??wt1�?�.Eric
>>> from arcpy.sa import * >>> m2w = Con(IsNull("wt1"),FocalStatistics("wt1", NbrRectangle(3,3),"MEAN"),"wt1")
Hi Matt,The FocalMean command you're familiar with is not available in the new raster calculator. The documentation you pointed to is wrong and I will submit a defect to have it changed. To accomplish this task you need to use FocalStatistics with the mean statistic type within your Con statement. It should look like this:**unspecified**= Con(IsNull("point2ras"),FocalStatistics("point2ras",NbrRectangle(3,3),"MEAN"),"point2ras")..........
Eric, I was currently solving this problem why it doesnt work for like 2 hours. Thanks alot for helping me!
