This was working before, but now I can't seem to get an ArcGS.com map to work. When I setup an ArcGIS Online Map service with a few feature layers and a tiled aerial mapservice we are serving up it works fine in ArcGIS.com or in an online JavaScript API-based editor. However, when I try to open up the map in Collector, every layer comes up separately with the same error: "Unable to load layer : (The Layer URL) from (Our ArcGIS URL)... Illegal start of token [<]"Has anyone else run into this issue?
Hi Dominick,
We are experiencing the same problem. It looks like our UAT and Prod ArcGIS Server external IP address are the same. A content switch is used to direct multiple fully qualified domain names to the respective back end server based on the hostname in the HTTP/HTTPS request. We didn't think it would pose an issue unless ArcGIS collector uses the direct IP address? Did you solve the issue by giving your ArcGIS Server a unique IP address?
Kind Regards
Alex
