Help, please.
Hi Gregory,
Currently, ESRI Maps for Office is only compatible with Microsoft Office 2010 and 2013:
Esri Maps for Office
Shall be another versions? Don't you know?
In time, Microsoft Office will be supported I'm sure. As of when, I cannot say.
O'kay, thank you.
Even though Esri Maps for Office isn't supported on Office 2016, I can confirm it is working for me...
Oscar, how did you get this to work? I was unable to install as the installer did not recognize Excel or PowerPoint 2016.
Jeff, I'm not sure.
I believe I just did an upgrade of Office from 2013-edition and the Esri Maps ribbon was still there.
2 dec. 2015 kl. 15:05 skrev Jeff Tucker <geonet@esri.com<mailto:geonet@esri.com>>:
GeoNet <https://community.esri.com/?et=watches.email.thread>
The EsriMaps doesn't work with the Office 2016. Isn't it?
reply from Jeff Tucker<https://community.esri.com/people/BusinessGeographer?et=watches.email.thread> in Esri Maps for Location Analytics - View the full discussion<https://community.esri.com/message/571806?et=watches.email.thread#571806>
Unfortunately, I uninstalled Office 2013 and then installed Office 2016. Consequently, the Esri installer doesn't recognize the 2016 version of Microsoft Office. Bummer!
Anyone had any luck installing this with Office 2016?
Interestingly I can attest to both cases above. I updated to Office 2016 on a Win 8.1 box that previously had Office 2013. I could get the Esri map add-in to install.
I just tried it on a new Win 10 box with a fresh install of Office 2016. Failed to install. To test, I then uninstalled the Office 2016 version, installed the Office 2013 version and then installed the Esri map add-in. After that I then installed the Office 2016 version on top of (I didn't uninstall) Office 2013 version. The Esri map add-in was enabled and functional.
If it matters, both of these were the 64 bit version of Office.
I installed today ESRI Maps for Office 4.0 (Office 2013). All worked fine creating the first map. I have tried 10 times after that with similar and different information, and the map does not show any information. Someone have had same or similar issue?
Thanks in advance.
Regards
Hi Luis - you may want to try your question over on the ArcGIS Maps for Office group. Also remember you can get in touch with our support team at Esri Support.
