Option Compare Database Option Explicit Private arcMapApp As esriArcMap.Application Public Sub setUpMap() 'Opens ArcMap, adds the shapefiles, and then modifies their representation On Error GoTo errorHandler [INDENT] Dim productKeyCheck As IAoInitialize Set productKeyCheck = New AoInitialize 'We check to make sure that no other instances are running with this key If productKeyCheck.IsProductCodeAvailable(esriLicenseProductCodeArcView) Then 'Initialize ArcView [INDENT] productKeyCheck.Initialize esriLicenseProductCodeArcView openMapTemplate addShapeFiles[/INDENT] Else [INDENT] MsgBox "Product Code Unavailable For Use", vbExclamation, _ "Product Code Unavailable"[/INDENT] End If productKeyCheck.Shutdown Set productKeyCheck = Nothing[/INDENT] Exit Sub errorHandler: MsgBox Err.Description, vbExclamation, "Error in setUpMap" End Sub Private Sub openMapTemplate() 'Opens ArcMap and sets the global variables On Error GoTo errorHandler [INDENT] Dim arcMapDocument As MxDocument Set arcMapDocument = New MxDocument Set arcMapApp = arcMapDocument.Parent arcMapApp.OpenDocument CurrentProject.Path & "\Distribution_Plot_Template.mxd" Set arcMapDocument = Nothing [/INDENT]Exit Sub errorHandler: MsgBox Err.Description, vbExclamation, "Error in openMapTemplate" End Sub Private Sub addShapeFiles() 'Adds the shapefiles to the map template On Error GoTo errorHandler [INDENT] Dim pMap As IMap Dim pFeatureLayer As IFeatureLayer Dim pFeatureWorkspace As IFeatureWorkspace Dim pMxDocument As IMxDocument Dim pWorkSpaceFactory As IWorkspaceFactory Set pWorkSpaceFactory = New ShapefileWorkspaceFactory Set pFeatureWorkspace = pWorkSpaceFactory.OpenFromFile(CurrentProject.Path & _ "\Claim_Shapefile\", arcMapApp.Hwnd) 'Set up the feature Layer Set pFeatureLayer = New featureLayer Set pFeatureLayer.FeatureClass = pFeatureWorkspace.OpenFeatureClass("Goldstone_Brookbank_Claims_605") pFeatureLayer.Name = pFeatureLayer.FeatureClass.AliasName pFeatureLayer.Visible = True 'Get the document Set pMxDocument = arcMapApp.Document 'Initialize the map and add the shape file to it Set pMap = pMxDocument.FocusMap pMap.AddLayer pFeatureLayer Set pMap = Nothing Set pMxDocument = Nothing Set pFeatureLayer = Nothing Set pFeatureWorkspace = Nothing Set pWorkSpaceFactory = Nothing[/INDENT] Exit Sub errorHandler: Set pMap = Nothing Set pMxDocument = Nothing Set pFeatureLayer = Nothing Set pFeatureWorkspace = Nothing Set pWorkSpaceFactory = Nothing MsgBox Err.Description, vbExclamation, "Error in addShapeFiles" End Sub
Your major problem seems to be your shapefile. Something wrong with your shapefile. Try to use Toolbox FeatureClasstoShapefile to generate your shapefile from Access if you can and see the result manually.
Private Sub openMap(filename As String) 'Opens the given file in ArcMap [INDENT] Dim arcMapDocument As MxDocument Set arcMapDocument = New MxDocument Set arcMapApp = arcMapDocument.Parent arcMapApp.OpenDocument filename Set arcMapDocument = Nothing[/INDENT] End Sub
'Initialize the map and add the shape file to it [INDENT]Set pMap = pMxDocument.FocusMap pMap.AddLayer pFeatureLayer arcMapApp.SaveAsDocument CurrentProject.Path & "\MapCopy.mxd" arcMapApp.Shutdown openMap CurrentProject.Path & "\MapCopy.mxd"[/INDENT]
