Hey everyone,I created the script below. It does this:- Creates a personal geodatabase
- spatial joins a point feature class with a point feature class
- Places the output spatial join into the new geodatabase
- Adds some fields and deletes some fields
- does an update cursor to compare 2 fields and and updates one of the new fields
When I run the script through, it retains the attribute for the first row and then all the remaining rows are empty. There is data in both the point feature class and the polygon feature class. These 2 feature classes overlap each other, so there definitely is a join of data. If I comment out everything after the spatial join and just allow the script to create the geodatabase and do the spatial join, the data is there. I've tried to comment out different section to test and it seems that anytime after the spatial join, the output feature classes manintains the first record and the rest are blank. I've tested with 3 different sets of data and nothing seems to work.This only happens when I run it as a tool. If I run from IDLE, the script works fine.
import arcpy
target_features = r"Z:\test.gdb\point"
join_features = r"Z:\test.gdb\polygon"
output_location = r"Z:\output_folder"
outputmbd = output_location + "\\" + "CompareTable.mdb"
out_feature_class = outputmbd + "\\" + "CompareTable"
arcpy.CreatePersonalGDB_management(output_location, "CompareTable.mdb")
arcpy.SpatialJoin_analysis(target_features, join_features, out_feature_class)
arcpy.AddField_management(out_feature_class, "Compare_Fields", "TEXT", "", "", 20)
arcpy.AddField_management(out_feature_class, "POLYGON_SITE", "TEXT", "", "", 10)
arcpy.CalculateField_management(out_feature_class, "POLYGON_SITE", "[SITE]", "VB")
arcpy.AddField_management(out_feature_class, "POINT_SITE", "TEXT", "", "", 10)
arcpy.CalculateField_management(out_feature_class, "POINT_SITE", "[SITE_1]", "VB")
fieldList = arcpy.ListFields(out_feature_class)
fieldNameList = []
for field in fieldList:
if not field.required and not field.name == "SITE" and not field.name == "SITE_ID" and not field.name == "POINT_SITE" and not field.name == "POLYGON_SITE":
fieldNameList.append(field.name)
print fieldNameList
arcpy.DeleteField_management(out_feature_class, fieldNameList)
cur = arcpy.UpdateCursor(out_feature_class)
for row in cur:
print row.POINT_SITE + " " + row.POLYGON_SITE
arcpy.AddMessage(row.POINT_SITE + " " + row.POLYGON_SITE)
if row.POLYGON_SITE == row.POINT_SITE:
row.Compare_Fields = "Same"
else:
row.Compare_Fields = "Inclusion"
cur.updateRow(row.Compare_Fields)
