Using a WebScene, how do I enable the "See through ground" option?
The AGOL viewer and PRO viewer have this functionality, so I know it exists, just can't seem to find the right property to set.
The property is basemapTerrain.opacity, change it from 1 to 0
It is the same code, in the require and function at the beginning of your script it is needed to add "esri/basemap" (even if yourself have not added any basemap in your local scene), then after the variable creating a "new SceneView" you add SceneViewVariableName.basemapTerrain.opacity = 0 as said above.
In 4.6, which object do I apply these property to? can't find either of the two in the reference.
The similar functionality is SceneView.basemapTerrain.wireframe, but the opacity property you mentioned is much more useful to me !
