I have a feature layer that i am trying to populate a field from another layer using a Dictionary/spatial join. I am getting "The field is not nullable" on line 38. Some feature are not within the polygonLayer = 'Soils", so i can see why it's not populating the Class_ID field but how do I by pass this "The field is not nullable" and keep going regardless if the point layer field is blank?
# Import arcpy module
import arcpy
import sys
import traceback
# scratch spatial join feature
sjpoints = "In_memory\SpJoin"
# define the field list from the spatial join to transfer
# you can add more field names such as: ["TARGET_FID", "Field", "AnoterField"]
sourceFieldsList = ["TARGET_FID", "Class_ID"]
# point feature that will be updated
pointLayer = "Bld_Class"
# polygon feature that will be used
polygonLayer = "Soils"
# define the field list to the original points
updateFieldsList = ["OID@", "Class"]
# Allow overwrite of join results
#Run the Spatial Join tool, using the defaults for the join operation and join type
arcpy.SpatialJoin_analysis(pointLayer, polygonLayer, sjpoints)
# populate the dictionary from the polygon
valueDict = {r[0]:(r[1:]) for r in arcpy.da.SearchCursor(sjpoints, sourceFieldsList)}
with arcpy.da.UpdateCursor(pointLayer, updateFieldsList) as cursor:
for Row in cursor:
keyValue = Row[0]
if keyValue in valueDict:
print keyValue
for n in range (1,len(sourceFieldsList)):
Row<N> = valueDict[keyValue][n-1]
cursor.updateRow(Row)
del valueDict
arcpy.Delete_management("In_memory\SpJoin")<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN></N>
