im working with the Javascript API 4.4 visualizing features on the map depending on a query.
The map is lagging while panning and zooming depending on the amount of features / size of the browser window and level of zoom. I am using Chrome as a browser.
I tried 2 things to visualize the features:
- Load the feature layer and do a definitionExpression by property afterwards. - This seemed to be a bad idea because when panning the map the query was executed again to fetch the features from the server.
- Create a query on the feature layer with a definitionExpression and than loop through all features on the feature service and add them to a graphicLayer.
rooms<SPAN class="punctuation token">.</SPAN><SPAN class="token function">queryFeatures</SPAN><SPAN class="punctuation token">(</SPAN>query1<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN>i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> result<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">addGraphicsToLayer</SPAN><SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
roomsGraphic<SPAN class="punctuation token">.</SPAN>visible <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>The addGraphicsToLayer() handles the symbolization based on attributes of the feature. Following the feature is added to the GraphicsLayer
roomsGraphic<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>feature<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
In both cases the map gets laggy while in 3.x i was able to create a smooth map with even more features from other services using "mode: esri.layers.FeatureLayer.MODE_SELECTION" (Feature Service 3.x) on each feature layer.
Is there another possibility to visualize features with a better performance on the view or am i missing something else?
Wiard
