You can select features in a map/list and have all of the chart widgets/indicators filter based on that selection; is it possible to make a selection in a chart and have it highlighted in the map?
yes
https://community.esri.com/thread/210373-serial-chart-zoom-to-features
Hi Reed,
Please see this help topic, Charts as the source of actions—Operations Dashboard for ArcGIS | ArcGIS
Hope this helps,
Derek
Thanks for the link. Yes, I've configured the chart so that the map responds when the selection changes.
However, if the map has multiple layers, (e.g. if the parent data layer is separated by attribute queries), is it possible to link them to the chart so that they would all respond when the selection changes?
Hi Arthur,
Apologies for the late reply, I've been out of the office on vacation after the esri virtual UC.
I'm not clear on what you mean by "if the parent data layer is separated by attribute queries" - can you please clarify/explain?
Hi, Reed, Derek!
As Reed said, you can link all dashboard elements to the map by going into the layer actions in the map's configure menu. e.g. when you select features in the map, the indicators, gauges, graphs and the other layers in the map (with the matching attribute) would respond.
In the link that you sent, you can link dashboard elements in the serial charts configure menu. I was able to link all the elements to the chart, but none of the map layer are available in the list (other than the source layer), even though they have matching attributes.
