I am trying to print a map using a print service. I have followed the example on the ArcGIS site namely:
Print templates with esri.request | ArcGIS API for JavaScript
However I can't get it to work using a local feature layer.
Can someone please give some advice.
Frank
This is what I have done so far:
<SPAN class="pln" style="color: #000000;">parser</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="pln" style="color: #000000;">parse</SPAN><SPAN class="pun" style="color: #145680;">();</SPAN><SPAN class="pln" style="color: #000000;"><BR /><BR /> app</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="pln" style="color: #000000;">printUrl </SPAN><SPAN class="pun" style="color: #145680;">=</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="str" style="color: #800000;"><SPAN>"</SPAN><A class="jive-link-external-small" href="http://aphrodite/arcgis/rest/services/Layout/WSC_LAYOUT1/GPServer/Export%20Web%20Map" rel="nofollow noopener noreferrer" target="_blank">http://aphrodite/arcgis/rest/services/Layout/WSC_LAYOUT1/GPServer/Export%20Web%20Map</A><SPAN>"</SPAN></SPAN><SPAN class="pun" style="color: #145680;">;</SPAN><SPAN class="pln" style="color: #000000;"><BR /><BR /> esri</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="pln" style="color: #000000;">config</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="pln" style="color: #000000;">defaults</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="pln" style="color: #000000;">io</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="pln" style="color: #000000;">corsEnabledServers</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="pln" style="color: #000000;">push</SPAN><SPAN class="pun" style="color: #145680;">(</SPAN><SPAN class="str" style="color: #800000;">"local_server"</SPAN><SPAN class="pun" style="color: #145680;">);</SPAN><SPAN class="pln" style="color: #000000;"><BR /><BR /> app</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="pln" style="color: #000000;">map </SPAN><SPAN class="pun" style="color: #145680;">=</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="kwd" style="color: #8a4a0b;">new</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="typ" style="color: #2b91af;">Map</SPAN><SPAN class="pun" style="color: #145680;">(</SPAN><SPAN class="str" style="color: #800000;">"map"</SPAN><SPAN class="pun" style="color: #145680;">);</SPAN><SPAN class="pln" style="color: #000000;"><BR /><BR /> </SPAN><SPAN class="com" style="color: #868686;">//Base map</SPAN><SPAN class="pln" style="color: #000000;"><BR /> </SPAN><SPAN class="kwd" style="color: #8a4a0b;">var</SPAN><SPAN class="pln" style="color: #000000;"> basemap </SPAN><SPAN class="pun" style="color: #145680;">=</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="kwd" style="color: #8a4a0b;">new</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="typ" style="color: #2b91af;">ArcGISDynamicMapServiceLayer</SPAN><SPAN class="pun" style="color: #145680;">(</SPAN><SPAN class="str" style="color: #800000;"><SPAN>"</SPAN><A class="jive-link-external-small" href="http://local_server/arcgis/rest/services/NAME/Basemap/MapServer/" rel="nofollow noopener noreferrer" target="_blank">http://local_server/arcgis/rest/services/NAME/Basemap/MapServer/</A><SPAN>"</SPAN></SPAN><SPAN class="pun" style="color: #145680;">);</SPAN><SPAN class="pln" style="color: #000000;"><BR /> basemap</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="pln" style="color: #000000;">setVisibleLayers</SPAN><SPAN class="pun" style="color: #145680;">([</SPAN><SPAN class="lit" style="color: #953838;">0</SPAN><SPAN class="pun" style="color: #145680;">,</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="lit" style="color: #953838;">1</SPAN><SPAN class="pun" style="color: #145680;">,</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="lit" style="color: #953838;">2</SPAN><SPAN class="pun" style="color: #145680;">,</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="lit" style="color: #953838;">3</SPAN><SPAN class="pun" style="color: #145680;">,</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="lit" style="color: #953838;">4</SPAN><SPAN class="pun" style="color: #145680;">,</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="lit" style="color: #953838;">5</SPAN><SPAN class="pun" style="color: #145680;">,</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="lit" style="color: #953838;">6</SPAN><SPAN class="pun" style="color: #145680;">,</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="lit" style="color: #953838;">7</SPAN><SPAN class="pun" style="color: #145680;">]);</SPAN><SPAN class="pln" style="color: #000000;"><BR /><BR /> app</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="pln" style="color: #000000;">map</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="pln" style="color: #000000;">addLayer</SPAN><SPAN class="pun" style="color: #145680;">(</SPAN><SPAN class="pln" style="color: #000000;">basemap</SPAN><SPAN class="pun" style="color: #145680;">);</SPAN><SPAN class="pln" style="color: #000000;"><BR /><BR /> </SPAN><SPAN class="com" style="color: #868686;">// add graphics for feature</SPAN><SPAN class="pln" style="color: #000000;"><BR /> </SPAN><SPAN class="kwd" style="color: #8a4a0b;">var</SPAN><SPAN class="pln" style="color: #000000;"> url </SPAN><SPAN class="pun" style="color: #145680;">=</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="str" style="color: #800000;"><SPAN>"</SPAN><A class="jive-link-external-small" href="http://local_server/arcgis/rest/services/NAME/NAME/FeatureServer/n" rel="nofollow noopener noreferrer" target="_blank">http://local_server/arcgis/rest/services/NAME/NAME/FeatureServer/n</A><SPAN>"</SPAN></SPAN><SPAN class="pun" style="color: #145680;">;</SPAN><SPAN class="pln" style="color: #000000;"><BR /> </SPAN><SPAN class="kwd" style="color: #8a4a0b;">var</SPAN><SPAN class="pln" style="color: #000000;"> pipeFeatureLayer </SPAN><SPAN class="pun" style="color: #145680;">=</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="kwd" style="color: #8a4a0b;">new</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="typ" style="color: #2b91af;">FeatureLayer</SPAN><SPAN class="pun" style="color: #145680;">(</SPAN><SPAN class="pln" style="color: #000000;">url</SPAN><SPAN class="pun" style="color: #145680;">,</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="pun" style="color: #145680;">{</SPAN><SPAN class="pln" style="color: #000000;"><BR /> </SPAN><SPAN class="str" style="color: #800000;">"mode"</SPAN><SPAN class="pun" style="color: #145680;">:</SPAN><SPAN class="pln" style="color: #000000;"> </SPAN><SPAN class="typ" style="color: #2b91af;">FeatureLayer</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="pln" style="color: #000000;">MODE_SNAPSHOT<BR /> </SPAN><SPAN class="pun" style="color: #145680;">});</SPAN><SPAN class="pln" style="color: #000000;"><BR /> app</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="pln" style="color: #000000;">map</SPAN><SPAN class="pun" style="color: #145680;">.</SPAN><SPAN class="pln" style="color: #000000;">addLayer</SPAN><SPAN class="pun" style="color: #145680;">(</SPAN><SPAN class="pln" style="color: #000000;">pipeFeatureLayer</SPAN><SPAN class="pun" style="color: #145680;">);</SPAN>
