<UserControl x:Class="MouseOverTest.MainPage" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:d="http://schemas.microsoft.com/expression/blend/2008" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" xmlns:esri="http://schemas.esri.com/arcgis/client/2009" mc:Ignorable="d" d:DesignWidth="780" d:DesignHeight="480" xmlns:i="clr-namespace:System.Windows.Interactivity;assembly=System.Windows.Interactivity" xmlns:ei="clr-namespace:Microsoft.Expression.Interactivity.Core;assembly=Microsoft.Expression.Interactions" xmlns:userControls="clr-namespace:ESRI.ArcGIS.SilverlightMapApp" xmlns:actions="clr-namespace:ESRI.ArcGIS.SilverlightMapApp.Actions"> <Grid x:Name="LayoutRoot"> <!-- Map Control --> <esri:Map x:Name="MyMap" Background="White"> <esri:ArcGISTiledMapServiceLayer ID="BaseLayer" Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" /> </esri:Map> <Border BorderThickness="2" BorderBrush="Black" Height="50" Width="100" Margin="12,418,668,12"> <TextBlock Name="mousePosition"/> </Border> </Grid> </UserControl>
using System; using System.Collections.Generic; using System.Linq; using System.Net; using System.Windows; using System.Windows.Browser; using System.Windows.Controls; using System.Windows.Documents; using System.Windows.Input; using System.Windows.Media; using System.Windows.Media.Animation; using System.Windows.Markup; using System.Windows.Shapes; using System.ComponentModel; using ESRI.ArcGIS.Client; using System.Windows.Controls.Primitives; namespace MouseOverTest { public partial class MainPage : UserControl { public MainPage() { InitializeComponent(); MyMap.Loaded += new RoutedEventHandler(MyMap_Loaded); } private void MyMap_Loaded(object sender, RoutedEventArgs e) { //choose what's best for your case MyMap.MouseEnter += new MouseEventHandler(MyMap_MouseEnter); MyMap.MouseMove += new MouseEventHandler(MyMap_MouseMove); MyMap.MouseLeave += new MouseEventHandler(MyMap_MouseLeave); } private void MyMap_MouseEnter(object sender, MouseEventArgs e) { mousePosition.Text = string.Format("OOB"); } private void MyMap_MouseMove(object sender, MouseEventArgs e) { mousePosition.Text = string.Format("X: {0}, Y:{1}", e.GetPosition(LayoutRoot).X.ToString(), e.GetPosition(LayoutRoot).Y); } private void MyMap_MouseLeave(object sender, MouseEventArgs e) { mousePosition.Text = string.Format("OOB"); } } }
Hi,I made a Small Application to demonstrate a possible solution to your problem.the Xaml has a Map and a Border with a TextBox that Show the mouse position on the screen or OOB (out of border) if the mouse is out of the map. here's the code:XAML: <UserControl x:Class="MouseOverTest.MainPage" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:d="http://schemas.microsoft.com/expression/blend/2008" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" xmlns:esri="http://schemas.esri.com/arcgis/client/2009" mc:Ignorable="d" d:DesignWidth="780" d:DesignHeight="480" xmlns:i="clr-namespace:System.Windows.Interactivity;assembly=System.Windows.Interactivity" xmlns:ei="clr-namespace:Microsoft.Expression.Interactivity.Core;assembly=Microsoft.Expression.Interactions" xmlns:userControls="clr-namespace:ESRI.ArcGIS.SilverlightMapApp" xmlns:actions="clr-namespace:ESRI.ArcGIS.SilverlightMapApp.Actions"> <Grid x:Name="LayoutRoot"> <!-- Map Control --> <esri:Map x:Name="MyMap" Background="White"> <esri:ArcGISTiledMapServiceLayer ID="BaseLayer" Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" /> </esri:Map> <Border BorderThickness="2" BorderBrush="Black" Height="50" Width="100" Margin="12,418,668,12"> <TextBlock Name="mousePosition"/> </Border> </Grid> </UserControl> CS: using System; using System.Collections.Generic; using System.Linq; using System.Net; using System.Windows; using System.Windows.Browser; using System.Windows.Controls; using System.Windows.Documents; using System.Windows.Input; using System.Windows.Media; using System.Windows.Media.Animation; using System.Windows.Markup; using System.Windows.Shapes; using System.ComponentModel; using ESRI.ArcGIS.Client; using System.Windows.Controls.Primitives; namespace MouseOverTest { public partial class MainPage : UserControl { public MainPage() { InitializeComponent(); MyMap.Loaded += new RoutedEventHandler(MyMap_Loaded); } private void MyMap_Loaded(object sender, RoutedEventArgs e) { //choose what's best for your case MyMap.MouseEnter += new MouseEventHandler(MyMap_MouseEnter); MyMap.MouseMove += new MouseEventHandler(MyMap_MouseMove); MyMap.MouseLeave += new MouseEventHandler(MyMap_MouseLeave); } private void MyMap_MouseEnter(object sender, MouseEventArgs e) { mousePosition.Text = string.Format("OOB"); } private void MyMap_MouseMove(object sender, MouseEventArgs e) { mousePosition.Text = string.Format("X: {0}, Y:{1}", e.GetPosition(LayoutRoot).X.ToString(), e.GetPosition(LayoutRoot).Y); } private void MyMap_MouseLeave(object sender, MouseEventArgs e) { mousePosition.Text = string.Format("OOB"); } } } I Hope this is useful XD
Hi I have a question on your code. at mousePosition.Text I'm getting "mouseposition" does not exist. Can you offer me some advice on that?Thanks
So when user loads the web application and they hover over the map before the page loads your code will let the page load without an error occuring??
well, I'm still new to silverlight, but in theory this code prevents the error, because the call that overrides the event MouseEnter, MouseMove and MouseLeave is only triggered after the map finishes loading, and, as I understood from your first post, the error ocurred because the map still didn't have an object instance.
In your MyMap_MouseMove, it doesn't seem to return the actual XY's from the Map. I'm guessing they are just the page XY's?? do you know how I can fix that?
private void MyMap_MouseMove(object sender, MouseEventArgs e) { //If you change LayoutRoot to any object that appears on the screen, the spacial //reference to the coordinates change, so, if you want the map coordinates, //you can change it to MyMap mousePosition.Text = string.Format("X: {0}, Y:{1}", e.GetPosition(LayoutRoot).X.ToString(), e.GetPosition(LayoutRoot).Y); mousePosition.Text = string.Format("X: {0}, Y:{1}", e.GetPosition(MyMap).X.ToString(), e.GetPosition(MyMap).Y); }
That actualy isn't hard.see this: private void MyMap_MouseMove(object sender, MouseEventArgs e) { //If you change LayoutRoot to any object that appears on the screen, the spacial //reference to the coordinates change, so, if you want the map coordinates, //you can change it to MyMap mousePosition.Text = string.Format("X: {0}, Y:{1}", e.GetPosition(LayoutRoot).X.ToString(), e.GetPosition(LayoutRoot).Y); mousePosition.Text = string.Format("X: {0}, Y:{1}", e.GetPosition(MyMap).X.ToString(), e.GetPosition(MyMap).Y); } This should fix it!Just to be sure, if your map is inside an ScrollViwer or a ChildWindow, this code Won't work well (i tried once, and i'm still trying to fix code for the childwindow)
