Runtime 100.4
Created a Mobile Map Package with ArcGIS Pro 2.3.1. When opening the .MMPK in a Runtime app, not all of the label classes are being recognized. Are there limitations? Is this a Pro/Runtime version compatibility issue?
Thanks!
I believe I have figured this one out on my own.
The label class was using a SQL Where clause similar to this:
MAJORROAD IN( NULL, 'NO' ,'N')
This works fine for data sourced in a file geodatabase, but it does not work in a Mobile Map Package because apparently SQLite does not support NULL as a value within an "IN" set. For compatibility with MMPK, you would need to re-write it as:
((MAJORROAD IS NULL) Or (MAJORROAD IN( 'NO', 'N' )))
I hope it helps someone else!
