I have followed the basic example for creating a SOAP Server Object Extension (SOE) using the walkthrough provided by ESRI, but have encountered a problem:[INDENT]It appears that ArcGIS Server is not looking in the "XmlClassRegistry" folder/sub-folders for files defining mappings between custom XML and COM-visible types.The effect is that any attempt to deserialize an XML type as its corresponding COM class fails with "Exception from HRESULT: 0x80043068" (XML_SERIALIZE_E_CANT_MAP_XMLTYPE_TO_CLASS).If the custom XML/COM type mapping definitions are moved to the "XmlSupport.dat" that ArcGIS Server uses to map ESRI types, then the custom types can be correctly deserialized.[/INDENT]Is there a defect in ArcGIS Server related to custom type deserialization, or is the SOAP SOE walkthrough incomplete in this regard?Any help would be greatly appreciated!Thanks
I am having this same problem. Can someone at ESRI comment? Who created this sample?
Lots of info in this thread.When I originally had this problem (at Arc 10.0), I believe it was attributed to my XML type-mapping file being in the wrong folder. The correct folder would be something like:[INDENT]C:\Program Files\Common Files\ArcGIS\Server10.2\XmlClassRegistry\YourOrganizationName\[/INDENT]The second time I had this problem (at Arc 10.1), it was related to the registering of my custom types. See NIM083300.
