Hi everybody,
as I landed here with the same warning message, I could fix my problem as following:
in my case the root cause, why the clip-analysis-tool was not working properly without the message „000117: Warning empty output generated”, seemed to be an entry for "definition query" in the layer properties: I just want to use a subset of my input features. After exporting the desired subset into an extra feature class and using this one as input features the problem was fixed.
My working environment:
• ArcGIS 10.2 Advanced
• Input features: File Geodatabase Feature Class, WGS84
• Clip features: Shape File Feature Class,WGS84
• worked with Python Window
• Environmental settings: no extra settings
Cheers, Sandra
Thanks everyone for helpful hints! I was trying to run clip in ArcMap 10.3.1, using a query layer county polygon to clip a statewide road feature class, and kept coming up "empty". Converting the query layer to a standalone single polygon feature class did not solve the problem, but running the Repair Geometry tool on both single county and road feature classes did. I was successful running clip tool from ArcCatalog.
I had the same problem and I used repair geometry and now I am able to clip the data with no Warning message! Thanks!
Hello everyone,
I'm having the same problem with my data set. I had converted raster data from USGS GAP data into polygons and I was clipping buffered polylines from the layers. Everything was working fine until I went to clip another polyline and then I got the zero output warning. As far as I know everything is set to WGS 1984(the data frame, datum, coordinate system). I tried merging all the polygons into a single polygon but I still have a zero output. I tried turning off the background geoprocessing and disabled the Windows Indexing Service but that did not work either. Everything else said to check the Extent environments to see if everything looks right. I do not have a lot of experience so I'm not sure what to look for but I have a feeling that my problem lies there. It's unusual that everything would be working fine for days, carrying out the same processing, and then suddenly not work. I'm hoping someone can give me some guidance, thanks again.
I ran into this when I was trying to clip a polyline layer with a polygon. I had a polyline selected that was outside the clip area. Clearing the selection fixed the problem for me.
I was misled while I had one datapoint (at the very edge of the extend) selected so the clip was empty 'cause it only clips what is selected ... took me a while. 🙂
Repair Geometry solved this error for me; thanks!
