Is there a way to make the esri/request synchronous?
esriRequest(url, { responseType: "json", callbackParamName: "callback" }).then(function(response){ console.log(resp); });
Thanks worked like a charm.
Meghan Kulkarni
Although I see you have the dojo class "request/xhr" property of sync set to a boolean value of true, then object still has a .then method promise.
Can you help me understand how this is synchronous please?
Hi Roshni,
I found another solution, I request myself with dojo class "request/xhr".
Regards,
Flavie
var layerInfo = null; var requestURL = layerUrl + "?f=json"; requestXHR(requestURL, { handleAs: "json", sync: true, headers: { "X-Requested-With": null } }).then(function(data){ layerInfo = data; }); return layerInfo;
Hi Flavie,
I had resolved this issue by making an API at my java code. And then call that API from my javascript making call synchronous.
Regards
Roshni
Hy roshni basu,
I ask myslef the same question. Have you found a way to do that?
