Public Function VisibleLayerList(ByVal MapService As ArcGISDynamicMapServiceLayer) As String Dim LayList As String For Each ly As LayerInfo In MapService.Layers If MapService.GetLayerVisibility(ly.ID) = True Then LayList += (ly.ID) & "," End If Next If LayList.EndsWith(",") Then LayList = LayList.Substring(0, LayList.Length - 1) End If Return LayList End Function
If you just want to check whether a layer is visible or not, you could work with ArcGISDynamicMapServiceLayer's VisibleLayers property. This returns an integer array, cast it to IList and use Contains() method to figure out if a specific layer is visible.
namespace DataContracts { [DataContract] public class LayersData { [DataMember(Name = "layers")] public IEnumerable<LayerData> Layers { get; set; } } [DataContract] public class LayerData // Only data for the sample -> to complete if needed { [DataMember(Name = "id")] public int Id { get; set; } [DataMember(Name = "type")] public String Type { get; set; } [DataMember(Name = "defaultVisibility")] public bool DefaultVisibility { get; set; } } }
void GetLayersAsync() { var json = new JsonReader<LayersData>(); json.OnCompleted += json_OnCompleted; json.GetData("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/layers?f=json"); } void json_OnCompleted(object sender, CompletedEventsArg<LayersData> e) { var layers = e.Result.Layers; if (layers != null) { // For sample : create an array with visible layers of type "Feature Layer" int[] visibleFeatureLayers = layers.Where(layer => layer.DefaultVisibility && layer.Type == "Feature Layer").Select(layer => layer.Id).ToArray(); ......... } }
