<!-- Snip inside MapTip of Feature --> <StackPanel Orientation="Vertical"> <Button x:Name="button" Background="Green" Width="40" Height="20" Content="button" Click="doThis" SEND TO VB SUB="{Binding[Field1]}" /> </StackPanel> <!-- Snip -->
<MediaElement x:Name="mPlayer2" Width="300" Height="250" AutoPlay="True" Source="/Videos/halo.mp4"/>
' Set Medial Player Source Dim Address = New Uri(Application.Current.Host.Source, "../Videos/halo.mp4") 'Dim Address = New Uri(Application.Current.Host.Source, "/Videos/halo.mp4") 'Dim Address = New Uri(Application.Current.Host.Source, "Videos/halo.mp4") mPlayer2.Source = Address ' Start Media Player mPlayer2.Stop() mPlayer2.Play()
' Set Medial Player Source Dim Address = New Uri(Application.Current.Host.Source, "../Videos/halo.wmv") mPlayer2.Source = Address ' Start Media Player mPlayer2.Stop() mPlayer2.Play()
Public Sub PlayVideo(ByVal videoName As String) 'MessageBox.Show(videoName) Dim Address = New Uri(Application.Current.Host.Source, "../Videos/" + videoName + ".wmv") Me.mPlayer3.Source = Address End Sub
Private Sub bPlay_Click3(ByVal sender As System.Object, ByVal e As System.Windows.RoutedEventArgs) mPlayer3.Stop() mPlayer3.Play() End Sub Private Sub bPause_Click3(ByVal sender As System.Object, ByVal e As System.Windows.RoutedEventArgs) If mPlayer3.CurrentState = MediaElementState.Paused Then mPlayer3.Play() Else mPlayer3.Pause() End If End Sub Private Sub bStop_Click3(ByVal sender As System.Object, ByVal e As System.Windows.RoutedEventArgs) mPlayer3.Stop() End Sub Private Sub bHide_Click3(ByVal sender As Object, ByVal e As EventArgs) mPlayer3.Stop() HideMedia3PlayerPanelNew.Begin() End Sub ' When the media opens, initialize the "Seek To" slider maximum value ' to the total number of miliseconds in the length of the media clip. Private Sub Element_MediaOpened3(ByVal sender As Object, ByVal args As RoutedEventArgs) timelineSlider3.Maximum = mPlayer3.NaturalDuration.TimeSpan.TotalMilliseconds End Sub ' When the media playback is finished. Stop() the media to seek to media start. Private Sub Element_MediaEnded3(ByVal sender As Object, ByVal args As RoutedEventArgs) mPlayer3.Stop() End Sub ' Jump to different parts of the media (seek to). Private Sub SeekToMediaPosition3(ByVal sender As Object, ByVal args As RoutedPropertyChangedEventArgs(Of Double)) Dim SliderValue3 As Integer = CType(timelineSlider3.Value, Integer) ' Overloaded constructor takes the arguments days, hours, minutes, seconds, miniseconds. ' Create a TimeSpan with miliseconds equal to the slider value. Dim ts As New TimeSpan(0, 0, 0, 0, SliderValue3) mPlayer3.Position = ts End Sub
<esri:FeatureLayer ID="MG_BusStops" Visible="False" Url="http://gis.org/arcgis/rest/services/MG_Test/MapServer/8" Renderer="{StaticResource BusStopUniqueRenderer}"> <esri:FeatureLayer.OutFields> <!-- OUTPUT FIELDS THAT ARE TO BE RETURNED IN THE MAP TIPS--> <sys:String>ELEM_TEXT</sys:String> <sys:String>Route</sys:String> <sys:String>Location</sys:String> <sys:String>Video</sys:String> </esri:FeatureLayer.OutFields> <esri:FeatureLayer.MapTip > <Border esri:GraphicsLayer.MapTipHideDelay="00:00:01.5" CornerRadius="10" BorderBrush="#FF222957" BorderThickness="0" Margin="0,0,15,15"> <Border.Background> <LinearGradientBrush EndPoint="1.038,1.136" StartPoint="0.015,0.188"> <GradientStop Color="#FFD1DFF2"/> <GradientStop Color="#FF092959" Offset="0.946"/> </LinearGradientBrush> </Border.Background> <Border.Effect> <DropShadowEffect ShadowDepth="10" BlurRadius="14" Direction="300" /> </Border.Effect> <Grid> <StackPanel Orientation="Vertical" Margin="10,10,0,10" VerticalAlignment="Center"> <Grid> <Button Content="GetMapTipValue" Width="100" Height="20" Command="{Binding ElementName=mainPage,Path= MapTipValueCommand1}" CommandParameter="{Binding}" /> </Grid> </StackPanel> </Grid> </Border> </esri:FeatureLayer.MapTip> </esri:FeatureLayer> <!-- Down further in the xaml file...in the map --> <Grid x:Name="Media3PlayerGrid" Height="0" RenderTransformOrigin="0.5,0.5"> <Grid.RenderTransform> <ScaleTransform x:Name="ResultsMedia3ScaleTransformNew" ScaleX="0" ScaleY="0" /> </Grid.RenderTransform> <Canvas> <MediaElement x:Name="mPlayer3" Width="300" Height="250" MediaOpened="Element_MediaOpened3" MediaEnded="Element_MediaEnded3" AutoPlay="True" /> <Button x:Name="bPlay3" Background="Green" Width="40" Height="20" Canvas.Left="8" Canvas.Top="220" Content="Play3" Click="bPlay_Click3" /> <Button x:Name="bPause3" Background="Yellow" Width="40" Height="20" Canvas.Left="112" Canvas.Top="220" Content="Pause3" Click="bPause_Click3" /> <Button x:Name="bStop3" Background="Red" Width="40" Height="20" Canvas.Left="216" Canvas.Top="220" Content="Stop3" Click="bStop_Click3" /> <Button x:Name="bHide3" Background="Red" Width="40" Height="20" Canvas.Left="260" Canvas.Top="220" Content="Hide3" Click="bHide_Click3" /> <TextBlock Foreground="Black" Margin="5" Canvas.Left="10" Canvas.Top="260" VerticalAlignment="Center">Seek To</TextBlock> <Slider Name="timelineSlider3" Margin="5" Width="180" Canvas.Left="60" Canvas.Top="260" ValueChanged="SeekToMediaPosition3"/> </Canvas> </Grid>
Public Sub PlayVideo(ByVal videoName As String) MessageBox.Show("in PlayVideo") MessageBox.Show(videoName) ' I get the correct values being passed in the messageboxes above ' I cannot set the darn media player defined in the xaml here....ugggggggggggg 'Dim Address = New Uri(Application.Current.Host.Source, "../Videos/halo.mp4") Dim Address = New Uri(Application.Current.Host.Source, "../Videos/" + videoName + ".mp4") Me.mPlayer3.Source = Address 'mPlayer3.Source = New Uri("../Videos/halo.mp4") 'mPlayer3.Source = New Uri("/Videos/halo.mp4") 'mPlayer3.Source = New Uri("Videos/halo.mp4") End Sub ' Snip #Region "Intersect command" Private m_mapTipValueCommand1 As MapTipValueCommand1 Public ReadOnly Property MapTipValueCommand1() As MapTipValueCommand1 Get If Me.m_mapTipValueCommand1 Is Nothing Then Me.m_mapTipValueCommand1 = New MapTipValueCommand1(Me) End If Return Me.m_mapTipValueCommand1 End Get End Property #End Region End Class Public Class MapTipValueCommand1 Implements ICommand Private _mainPage As MainPage Public Sub New(ByVal mainPage As MainPage) Me._mainPage = mainPage End Sub Public Function CanExecute(ByVal parameter As Object) As Boolean Implements System.Windows.Input.ICommand.CanExecute Return True End Function Public Event CanExecuteChanged(ByVal sender As Object, ByVal e As System.EventArgs) Implements System.Windows.Input.ICommand.CanExecuteChanged Public Sub Execute(ByVal parameter As Object) Implements System.Windows.Input.ICommand.Execute Dim result2 = DirectCast(parameter, IDictionary(Of String, Object)) 'MessageBox.Show(result2("Video").ToString()) Dim videoName = result2("Video").ToString() Me._mainPage.PlayVideo(videoName) End Sub End Class
<MediaElement x:Name="showVideo" Height="161" Width="215" HorizontalAlignment="Left" VerticalAlignment="Top" IsMuted="True" AutoPlay="True"> </MediaElement>
Public Sub PlayVideo(videoName As String) Dim Address = New Uri(Application.Current.Host.Source, "../Video/" + videoName + ".wmv") Me.showVideo.Source = Address End Sub
Public Sub PlayVideo(ByVal videoName As String) ' return video path and name MessageBox.Show(videoName) ' Hard Code the Path adn File Dim Address = New Uri(Application.Current.Host.Source, "/Videos/halo.mp4") ' Set the source of the medie element Me.mPlayer2.Source = Address ' Open the media player ShowMediaPlayerPanelNew.Begin() ' Start the media player mPlayer2.Play() End Sub
#Region "Intersect command" Private m_mapTipValueCommand1 As MapTipValueCommand1 Public ReadOnly Property MapTipValueCommand1() As MapTipValueCommand1 Get If Me.m_mapTipValueCommand1 Is Nothing Then Me.m_mapTipValueCommand1 = New MapTipValueCommand1() End If Return Me.m_mapTipValueCommand1 End Get End Property #End Region
Public Class MapTipValueCommand1 Implements ICommand Private _mainPage As MainPage Public Sub New(mainPage As MainPage) Me._mainPage = mainPage End Sub Public Function CanExecute(ByVal parameter As Object) As Boolean Implements System.Windows.Input.ICommand.CanExecute Return True End Function Public Event CanExecuteChanged(ByVal sender As Object, ByVal e As System.EventArgs) Implements System.Windows.Input.ICommand.CanExecuteChanged Public Sub Execute(ByVal parameter As Object) Implements System.Windows.Input.ICommand.Execute Dim result2 = DirectCast(parameter, IDictionary(Of String, Object)) Dim videoName = result2("NAME").ToString() Me._mainPage.PlayVideo(videoName) End Sub End Class
Public Class MapTipValueCommand1 Implements ICommand Public Function CanExecute(ByVal parameter As Object) As Boolean Implements System.Windows.Input.ICommand.CanExecute Return True End Function Public Event CanExecuteChanged(ByVal sender As Object, ByVal e As System.EventArgs) Implements System.Windows.Input.ICommand.CanExecuteChanged Public Sub Execute(ByVal parameter As Object) Implements System.Windows.Input.ICommand.Execute Dim result2 = DirectCast(parameter, IDictionary(Of String, Object)) MessageBox.Show(result2("Video").ToString()) ShowMediaPlayerPanelNew.Begin() End Sub End Class
Public Sub Execute(ByVal parameter As Object) Implements System.Windows.Input.ICommand.Execute Dim result2 = DirectCast(parameter, IDictionary(Of String, Object)) MessageBox.Show(result2("Video").ToString()) Call Sub in Main vb and pass the Video value to it and return Message box there End Sub
Partial Public Class MainPage Inherits UserControl Public Sub New() InitializeComponent() End Sub #Region "Intersect command" Private m_mapTipValueCommand1 As MapTipValueCommand1 Public ReadOnly Property MapTipValueCommand1() As MapTipValueCommand1 Get If Me.m_mapTipValueCommand1 Is Nothing Then Me.m_mapTipValueCommand1 = New MapTipValueCommand1() End If Return Me.m_mapTipValueCommand1 End Get End Property #End Region End Class Public Class MapTipValueCommand1 Implements ICommand Public Function CanExecute(ByVal parameter As Object) As Boolean Implements System.Windows.Input.ICommand.CanExecute Return True End Function Public Event CanExecuteChanged(ByVal sender As Object, ByVal e As System.EventArgs) Implements System.Windows.Input.ICommand.CanExecuteChanged Public Sub Execute(ByVal parameter As Object) Implements System.Windows.Input.ICommand.Execute Dim result2 = DirectCast(parameter, IDictionary(Of String, Object)) MessageBox.Show(result2("NAME").ToString()) End Sub End Class
<UserControl x:Class="SilverlightApplication1_VB.MainPage" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:d="http://schemas.microsoft.com/expression/blend/2008" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" xmlns:esri="http://schemas.esri.com/arcgis/client/2009" mc:Ignorable="d" d:DesignHeight="300" d:DesignWidth="400" x:Name="mainPage"> <Grid x:Name="LayoutRoot"> <!-- Map Control --> <esri:Map x:Name="MyMap" Extent="-15000000,2000000,-7000000,8000000"> <esri:ArcGISTiledMapServiceLayer ID="StreetMapLayer" Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" /> <esri:FeatureLayer ID="MyFeatureLayer" Url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/3"> <esri:FeatureLayer.MapTip> <Border esri:GraphicsLayer.MapTipHideDelay="00:00:05" CornerRadius="10" BorderBrush="#FF222957" BorderThickness="0" Margin="0,0,15,15"> <Border.Background> <LinearGradientBrush EndPoint="1.038,1.136" StartPoint="0.015,0.188"> <GradientStop Color="#FFD1DFF2" /> <GradientStop Color="#FF092959" Offset="0.946" /> </LinearGradientBrush> </Border.Background> <Border.Effect> <DropShadowEffect ShadowDepth="10" BlurRadius="14" Direction="300" /> </Border.Effect> <Grid> <StackPanel Orientation="Vertical" Margin="10,10,0,10" VerticalAlignment="Center"> <Grid> <Button Content="GetMapTipValue" Width="100" Height="20" Command="{Binding ElementName=mainPage,Path= MapTipValueCommand1}" CommandParameter="{Binding}" /> </Grid> </StackPanel> </Grid> </Border> </esri:FeatureLayer.MapTip> </esri:FeatureLayer> </esri:Map> </Grid> </UserControl>
<Button Content="GetMapTipValue" Width="100" Height="20" Command="{Binding MapTipValueCommand}" CommandParameter="{Binding}" />
<!-- Snip User Control --> xmlns:ViewModel="clr-namespace:gislis2010_live.ViewModel"> <!-- Snip MapTip --> <UserControl.Resources> <ViewModel:MainPageViewModel x:Key="vm" /> </UserControl.Resources> <!-- Snip MapTip --> <Button Content="GetMapTipValue" Width="100" Height="20" Command="{Binding Source={StaticResource vm},Path= MapTipValueCommand}" CommandParameter="{Binding}" /> <!-- Snip MapTip -->
Imports System Imports System.Net Imports System.Windows Imports System.Windows.Controls Imports System.Windows.Documents Imports System.Windows.Ink Imports System.Windows.Input Imports System.Windows.Media Imports System.Windows.Media.Animation Imports System.Windows.Shapes Imports System.Collections.Generic Namespace gislis2010_live.Commands Public Class MapTipValueCommand Implements ICommand Public Function CanExecute(ByVal parameter As Object) As Boolean Implements System.Windows.Input.ICommand.CanExecute Return True End Function Public Event CanExecuteChanged(ByVal sender As Object, ByVal e As System.EventArgs) Implements System.Windows.Input.ICommand.CanExecuteChanged Public Sub Execute(ByVal parameter As Object) Implements System.Windows.Input.ICommand.Execute Dim result2 = DirectCast(parameter, IDictionary(Of String, Object)) MessageBox.Show(result2("Video").ToString()) End Sub End Class End Namespace
Imports System Imports System.Net Imports System.Windows Imports System.Windows.Controls Imports System.Windows.Documents Imports System.Windows.Ink Imports System.Windows.Input Imports System.Windows.Media Imports System.Windows.Media.Animation Imports System.Windows.Shapes Imports gislis2010_live.Commands Namespace gislis2010_live.ViewModel Public Class MainPageViewModel Inherits DependencyObject Public Sub New() End Sub #Region "Intersect command" Private m_mapTipValueCommand As MapTipValueCommand Public ReadOnly Property MapTipValueCommand() As MapTipValueCommand Get If Me.m_mapTipValueCommand Is Nothing Then Me.m_mapTipValueCommand = New MapTipValueCommand() End If Return Me.m_mapTipValueCommand MessageBox.Show("In the Get") End Get End Property #End Region End Class End Namespace
<esri:FeatureLayer ID="Stops" Visible="False" Url="http://gi.org/arcgis/rest/services/MG_Test/MapServer/8" Renderer="{StaticResource BusStopUniqueRenderer}"> <esri:FeatureLayer.OutFields> <sys:String>Video</sys:String> </esri:FeatureLayer.OutFields> <esri:FeatureLayer.MapTip > <Border esri:GraphicsLayer.MapTipHideDelay="00:00:01.5" CornerRadius="10" BorderBrush="#FF222957" BorderThickness="0" Margin="0,0,15,15"> <Border.Background> <LinearGradientBrush EndPoint="1.038,1.136" StartPoint="0.015,0.188"> <GradientStop Color="#FFD1DFF2"/> <GradientStop Color="#FF092959" Offset="0.946"/> </LinearGradientBrush> </Border.Background> <Border.Effect> <DropShadowEffect ShadowDepth="10" BlurRadius="14" Direction="300" /> </Border.Effect> <Grid> <StackPanel Orientation="Vertical" Margin="10,10,0,10" VerticalAlignment="Center"> <Grid> <Button Content="GetMapTipValue" Width="100" Height="20" Command="{Binding MapTipValueCommand}" CommandParameter="{Binding ElementName=MyMapTip}"/> </Grid> </StackPanel> </Grid> </Border> </esri:FeatureLayer.MapTip> </esri:FeatureLayer>
Public Class MapTipValueCommand Implements ICommand Public Function CanExecute(ByVal parameter As Object) As Boolean Implements System.Windows.Input.ICommand.CanExecute Return True End Function Public Event CanExecuteChanged(ByVal sender As Object, ByVal e As System.EventArgs) Implements System.Windows.Input.ICommand.CanExecuteChanged Public Sub Execute(ByVal parameter As Object) Implements System.Windows.Input.ICommand.Execute Dim result = DirectCast(parameter, ESRI.ArcGIS.Client.Toolkit.MapTip) Dim result2 = DirectCast(result.ItemsSource, IDictionary(Of String, Object)) MessageBox.Show(result2("Video").ToString()) End Sub End Class
Public Class MapTipValueCommand Implements ICommand Public Function CanExecute(parameter As Object) As Boolean Implements System.Windows.Input.ICommand.CanExecute Return True End Function Public Event CanExecuteChanged(sender As Object, e As System.EventArgs) Implements System.Windows.Input.ICommand.CanExecuteChanged Public Sub Execute(parameter As Object) Implements System.Windows.Input.ICommand.Execute Dim result = DirectCast(parameter, ESRI.ArcGIS.Client.Toolkit.MapTip) Dim result2 = DirectCast(result.ItemsSource, IDictionary(Of String, Object)) MessageBox.Show(result2("Field1").ToString()) End Sub End Class
<!-- Snip from Map Tip --> <Button x:Name="bTurnOn3" Background="Red" Width="40" Height="20" Content="TurnON" Click="bTurnOn_Click3" Command="{Binding MapTipValueCommand}" CommandParameter="{Binding ElementName=MyMapTip}"/> <!-- Snip from Map Tip -->
Private m_mapTipValueCommand As MapTipValueCommand Public ReadOnly Property MapTipValueCommand() As MapTipValueCommand Get If Me.m_mapTipValueCommand Is Nothing Then Me.m_mapTipValueCommand = New MapTipValueCommand() End If Return Me.m_mapTipValueCommand End Get End Property
Public Class MapTipValueCommand Implements ICommand Public Function CanExecute(ByVal parameter As Object) As Boolean Return True End Function Public Event CanExecuteChanged As EventHandler Public Sub Execute(ByVal parameter As Object) Dim result = DirectCast(parameter, ESRI.ArcGIS.Client.Toolkit.MapTip) Dim result2 = DirectCast(result.ItemsSource, IDictionary(Of String, Object)) MessageBox.Show(result2("Field1").ToString()) End Sub End Class
<!-- Snip inside MapTip of Feature --> <Button Content="GetMapTipValue" Height="30" Width="150" Command="{Binding MapTipValueCommand}" CommandParameter="{Binding ElementName=MyMapTip}"> </Button> <!-- Snip inside MapTip of Feature -->
private MapTipValueCommand mapTipValueCommand; public MapTipValueCommand MapTipValueCommand { get { if (this.mapTipValueCommand == null) { this.mapTipValueCommand = new MapTipValueCommand(); } return this.mapTipValueCommand; } }
public class MapTipValueCommand:ICommand { public bool CanExecute(object parameter) { return true; } public event EventHandler CanExecuteChanged; public void Execute(object parameter) { var result = (ESRI.ArcGIS.Client.Toolkit.MapTip)parameter; var result2 = (IDictionary<string, object>)result.ItemsSource; MessageBox.Show(result2["xyz"].ToString()); } }
Private _getMapTipValue As ICommand(Of Object) Public ReadOnly Property GetMapTipValue() As ICommand(Of Object) Get If Me._getMapTipValue Is Nothing Then Me._getMapTipValue = New ICommand(Of Object)(AddressOf GetMapTipValueRelayMethod) End If Return Me._getMapTipValue End Get End Property
Private _getMapTipValue As RelayCommand(Of Object) Public ReadOnly Property GetMapTipValue() As RelayCommand(Of Object) Get If Me._getMapTipValue Is Nothing Then Me._getMapTipValue = New RelayCommand(Of Object)(AddressOf GetMapTipValueRelayMethod) End If Return Me._getMapTipValue End Get End Property Private Sub GetMapTipValueRelayMethod(ByVal commandParameter As Object) Dim result = DirectCast(commandParameter, ESRI.ArcGIS.Client.Toolkit.MapTip) Dim result2 = DirectCast(result.ItemsSource, IDictionary(Of String, Object)) MessageBox.Show(result2("Field1").ToString()) End Sub
I have a MapTip that is returning a value from a field....I need this value to be pushed to the VB code so I can do soemthing with it... Can that be done...Say inthe Map Tip below I have this....when I click the Button it sends a Binding Value from a field to the VB Sub.... This is the field that I need the bound field value "{Binding [Field1]}" sent to the vb Sub "doThis" as seen below... From a MapTip can I send a Binding Value to a VB sub ???? THanks <!-- Snip inside MapTip of Feature --> <StackPanel Orientation="Vertical"> <Button x:Name="button" Background="Green" Width="40" Height="20" Content="button" Click="doThis" SEND TO VB SUB="{Binding[Field1]}" /> </StackPanel> <!-- Snip -->
<!-- Snip inside MapTip of Feature --> <StackPanel Orientation="Vertical"> <Button x:Name="button" Background="Green" Width="40" Height="20" Content="button" Command="{Binding GetMapTipValue}" CommandParameter="{Binding ElementName=MyMapTip}" </StackPanel> <!-- Snip -->
private RelayCommand<object> _getMapTipValue; public RelayCommand<object> GetMapTipValue { get { if (this._getMapTipValue == null) { this._getMapTipValue = new RelayCommand<object>(GetMapTipValueRelayMethod); } return this._getMapTipValue; } } private void GetMapTipValueRelayMethod(object commandParameter) { var result = (ESRI.ArcGIS.Client.Toolkit.MapTip)commandParameter; var result2 = (IDictionary<string, object>)result.ItemsSource; MessageBox.Show(result2["Field1"].ToString()); }
