I'm trying to follow the documentation on this page: Create Map Area—ArcGIS REST API: Packaging Service | ArcGIS for Developers but I get an "Services Directory has been disabled" error message.
I have tried with this WebMap, using POST:
curl -X POST \ 'https://packaging.arcgis.com/arcgis/rest/services/OfflinePackaging/GPServer' \ -H 'cache-control: no-cache' \ -H 'content-type: multipart/form-data; boundary=----WebKitFormBoundary7MA4YWxkTrZu0gW' \ -F mapItemId=4965122d0a9c4ea187fa643cda58c670 \ -F token=MY_TOKEN_HERE
And also GET:
curl -X GET \ 'https://packaging.arcgis.com/arcgis/rest/services/OfflinePackaging/GPServer?mapItemId=4965122d0a9c4ea187fa643cda58c670&token=MY_TOKEN_HERE' \
Am I doing something wrong?
Thanks in advance,
Raúl
cc: Patrick Arlt, John Gravois, Matthias Schenker, Paul Ross
First, URL should be <SPAN class="">https:</SPAN>/<SPAN class="">/packaging.arcgis.com/arcgis</SPAN><SPAN class="">/rest/services</SPAN><SPAN class="">/OfflinePackaging/</SPAN>GPServer/CreateMapArea/submitJob
</CODE></P><P><CODE>Second, in POST encode form parameters using "application/x-www-form-urlencoded" (instead of "multipart/form-data")<BR />
Thank you very much Ramunas Kraujutis, I have just tried this:
curl -X POST \ https://packaging.arcgis.com/arcgis/rest/services/OfflinePackaging/GPServer/CreateMapArea/submitJob \ -H 'cache-control: no-cache' \ -H 'content-type: application/x-www-form-urlencoded' \ -d 'mapItemId=4965122d0a9c4ea187fa643cda58c670&token=MY_TOKEN_HERE'
But I'm still getting the same response, maybe I didn't understand your message, did I?
Cheers,
Raul
Try adding "f=json" to "-d 'f=json&mapItemId=4965122d0a9c4ea187fa643cda58c670&token=MY_TOKEN_HERE'"
Thanks Ramunas Kraujutis!! it works now!
So finally I created this item: http://www.arcgis.com/home/item.html?id=444e615e7b9f471ab2a4c5d9194b538e#overview
I have added this request to a Postman collection we started on Github.
Thanks again!
Sir, I m facing an issue at the very next stage of this packaging service "Setup Map Area". While submitting job went successful, it gives job failure error on the status check which I posted in this question.
https://community.esri.com/message/756213-error-in-executing-agol-rest-api-packaging-service
Can you help me in figuring out how to set these parameters which I highlighted in red color.
