<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html lang="en"> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" /> <title>Dynamically Create Map Service Layer List</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dijit/themes/claro/claro.css"> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8"></script> <script type="text/javascript"> dojo.require("esri.map"); var layer, map, visible = []; function init() { map = new esri.Map("map"); layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://le/ArcGIS/rest/services/USA/MapServer"); if (layer.loaded) { buildLayerList(layer); } else { dojo.connect(layer, "onLoad", buildLayerList); } } function buildLayerList(layer) { var items = dojo.map(layer.layerInfos, function (info, index) { if (info.defaultVisibility) { visible.push(info.id); } var inputString = "<input type='checkbox' class='list_item' " + (info.defaultVisibility ? " checked='checked'" : "") + " id='" + info.id + "' onclick='updateLayerVisibility();' /><label for='" + info.id + "'>" + info.name + "</label>"; return inputString; }); dojo.byId("layer_list").innerHTML = items.join(); layer.setVisibleLayers(visible); map.addLayer(layer); } function updateLayerVisibility() { var inputs = dojo.query(".list_item"), input; visible = []; dojo.forEach(inputs, function (input) { if (input.checked) { visible.push(input.id); } }); //if there aren't any layers visible set the array to be -1 if (visible.length === 0) { visible.push(-1); } layer.setVisibleLayers(visible); } dojo.addOnLoad(init); </script> </head> <body> This sample loads an ArcGISDynamicMapServiceLayer.<br /> It determines the layers in the map service and presents them as checkboxes that can be used to toggle their visibility.<br /> <br /> Layer List : <span id="layer_list"></span> <br /> <br /> <div id="map" class="claro" style="width: 600px; height: 400px; border: 1px solid #000;"> </div> </body> </html>
