I recall having this problem too. By setting autoNavigate to false, I was able to get the map to refresh properly. I also set the zoom scale to 17.Hope you are staying dry out there in CO.
var myGeocoders = [ { url: "http://ndis-flex.nrel.colostate.edu/ArcGIS/rest/services/AddressLocator_All2/GeocodeServer", name: "AddressLocator_All2", placeholder: "Search for a Colorado Place...", minCharacters: 8, singleLineFieldName: "PlaceName", outFields: ["*"] }]; geocoder = new esri.dijit.Geocoder({ autoNavigate: true, // do not zoom to best result autoComplete: true, showResults: true, // when true, suggestions are displayed as the user is typing maxLocations: 20, map: map, arcgisGeocoder: false, geocoders: myGeocoders }, "search"); geocoder.startup(); // When geocoding is complete. this is also run when you highlight the typed in text to erase it. geocoder.on("select", function(results) { if (results.result) map.centerAndZoom(results.result.feature.geometry, 11); //map.setExtent(esri.geometry.getExtentForScale(map, "144448")); //map.setScale(144448); });
var gc = [{ url: "http://MyServer/arcgis/rest/services/MyGeocoder/GeocodeServer", name: "Geocoder", singleLineFieldName: "Street" }]; var geocoder = new esri.dijit.Geocoder({ map: map, autoNavigate: false, autoComplete: true, geocoders: gc, geocoderMenu: false, arcgisGeocoder: false, placeholder: "142 East Main St" }, "search"); geocoder.startup(); geocoder.on("find-results", showResults);
function showResults(results) { var geom; for (var i = 0; i < results.results.results.length; i++) { console.debug(results.results.results, " at index ", i); geom = results.results.results[0].feature.geometry; } map.centerAndZoom(geom, 20); geocoder.inputNode.blur(); }
var gc = [{ url: "http://MyURL/arcgis/rest/services/myGeocoder/GeocoderServer", name: "theGeocoder", singleLineFieldName: "Street" }]; var geocoder = new esri.dijit.Geocoder({ map: map, autoNavigate: true, autoComplete: true, geocoders: gc, geocoderMenu: false, arcgisGeocoder: false, placeholder: "142 East Main St" }, "search"); geocoder.startup();
geocoder = new esri.dijit.Geocoder({ map: map, autocomplete: true, placehoder: "Find a place", //searchExtent: search_extent, arcgisGeocoder: { name: "Esri World Geocoder" } }, "search"); geocoder.startup();
"Street": dom.byId("address").value
var myGeocoders = [{ url: locatorUrl, name: "Meriden", //if your locator uses a single line input field name other than 'Single Line Input', //tell the widget how to make the appropriate request singleLineFieldName: "Street" }]; geocoder = new Geocoder({ map: map, autocomplete: true, arcgisGeocoder: false, geocoders: myGeocoders, value: "Main St." },"search");
