Sorry, my lacking scripting/syntax knowledge is what holds me back here. Here is what I am putting in as directed, yet the values are not calculated. Did I enter the right field in the output?
This requires that you check the box to allow for a codeblock located just above the expression text box. This will create two entry textboxes, with the top one being for code and the bottom one being the output to the field. I would do it this way in VB Script (Python can also do it but I am a VB guy)Parser: VB ScriptUse Codeblock: checkedPre-Logic Codeblock:[ATTACH=CONFIG]30393[/ATTACH]Expression: OutputFor the bracketed field names in the Pre-Logic Codeblock replace them with whatever the field list inserts to handle the join qualification of the field names. You have to output a value for every record, so the only way to prevent an error or a change to an existing value is to overwrite the existing value with itself.
Is there a way to write an If then statement in the Field Calculator? ie. If the UpstreamElevation is <Null> then UpstreamElev=InvertElevThis way I dont overwrite values in the Upstream Elevation field that are already in there?
If IsNull([UpstreamElev]) Then Output = [InvertElev] Else Output = [UpstreamElev] End If
Howdy,I have joined a sewer Gravity Main (pipes) table to my Manholes table based on [From_Manhole]. My next step was using the field calculator set the values of [Upstream_Elevation] in my Gravity Mains table equal to the values of [Invert_Elevation] from the joined Manholes table. However, when I try to execute this function, I get an error message. Am I using the right expression? The input field and destination fields are both Double with a precision of 38... not sure if this matters? Here is what the geoprocessing results showed me:infrastructure.PUBLICWORKS.ssGravityMain.Upstream_Elev= [infrastructure.PUBLICWORKS.ssManhole.INVERTELEV]General Error executing calculatorERROR 9999999Syntax errorFailed to execute
