#compass { background : transparent url('../../../../images/compass.png') center no-repeat; height:100px; left:0; position:absolute; top:0; width:100px; z-index:10; } #onepixel { background : transparent url('../../../../images/1by1.png') center no-repeat; height:1px; left:0; position:absolute; top:0; width:1px; z-index:9; }
I tried adding a topmost graphic like you said but it didn't help. Luckily for me I found another way to solve it. Try adding the IE compatibility meta tag to your page. At a minimum make sure it includes the "IE=7" because "IE=edge" alone isn't enough.
<meta http-equiv="X-UA-Compatible" content="IE=7, IE=edge" />
jeff.pacewhat function are you using to print? This is more than likely due to the wonderful fact the IE does not support svg and therefore using a vml graphics renderer.
Good afternoon, I'm building dynamic reports that pull tract data from our database. I include a map of the location at the bottom of the page. When I print the report in standard-compliant browsers, everything displays properly. When using Internet Explorer 8, however, only the map itself prints - the map.graphics layer does not print. Searched for a solution to this issue to no avail... this thread was the closest I found but had no resolution that seemed effective. Tried selecting 'Print background images & colors' in IE preferences - no dice.I don't believe I'm doing anything wrong with my function call to draw the graphics (they do display across all browsers on-screen), here it is for reference:sendQuery = task.execute(query); sendQuery.then(function(loc) { symbol = new esri.symbol.SimpleFillSymbol(); symbol.setColor(new dojo.Color([255,0,0,0.5])); gfx= loc.features[0].geometry; map.graphics.add(new esri.Graphic(gfx, symbol)); });The obvious answer, 'print from FF', unfortunately doesn't work because IE support is a requirement for the report. Any thoughts or code snippets that can get me going in the right direction would be greatly appreciated! Thanks in advance!Jim
