Hi Michelle,You may be running into a bug, NIM084485.Synopsis In the Land Use Public Notification local government template, there are improperly defined workspaces in the GenerateCSV and GenerateAveryLabelsPDF tools in PublicNotification.tbx. Additional Status InformationFixed in the November 2012 Release Alternate SolutionEdit the script tools to be published as geoprocessing services for the Land Use Public Notification local government template to use the %scratchfolder% environment.
For the token issue, it looks like your address search endpoint requires a token. The easiest fix would be to change the security on that service so that it no longer requires a token. Otherwise you'll need to either use the IdentityManager object in your JavaScript code to have the user log in, or, if you don't want users to have to log in, handle the login on the server-side using a proxy.
