Take the following code and notice that in the browser's javascript console that the map info window's coords, anchor and fixed anchor properites are 'undefined'. Why? Am I using the info window incorrectly? Does this have anything to do with it not having a symbol associated with it? The docs don't make it at all clear what I might be doing wrong.<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Info Window Tests</title> <!-- ESRI Required --> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/esri/css/esri.css" /> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/dojo/dijit/themes/tundra/tundra.css"/> <script type="text/javascript">var dojoConfig = { parseOnLoad: true };</script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4"></script> <script type="text/javascript"> dojo.require("esri.map"); var map; var streetsUrl = "http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"; function init() { var initExtent = new esri.geometry.Extent({ "xmin": -13646149, "ymin": 3606604, "xmax": -12393805, "ymax": 4232776, "spatialReference": { "wkid": 102100} }); map = new esri.Map("map", { extent: initExtent }); var layer0 = new esri.layers.ArcGISTiledMapServiceLayer(streetsUrl, { "id": "Streets", "opacity": 1.0, "visible": true }); var BASE_MAP_ARRAY = [layer0]; map.addLayers(BASE_MAP_ARRAY); dojo.connect(map, "onLoad", function (map) { map.infoWindow.resize(250, 100); }); dojo.connect(map, "onClick", addPoint); dojo.connect(map.infoWindow, "onShow", onInfoWindowShown); } function addPoint(evt) { map.infoWindow.setTitle("Coordinates"); //Need to convert the coordinates from the map's spatial reference (web mercator) to geographic to display lat/lon values var geoPt = esri.geometry.webMercatorToGeographic(evt.mapPoint); map.infoWindow.setContent("lat/lon : " + geoPt.y.toFixed(2) + ", " + geoPt.x.toFixed(2) + "<br />screen x/y : " + evt.screenPoint.x + ", " + evt.screenPoint.y); map.infoWindow.show(evt.mapPoint, map.getInfoWindowAnchor(evt.screenPoint)); } function onInfoWindowShown() { logMessage("info window coords: " + map.infoWindow.coords); logMessage("info window anchor: " + map.infoWindow.anchor); logMessage("info window fixed anchor: " + map.infoWindow.fixedAnchor); logMessage("info window isShowing: " + map.infoWindow.isShowing); } function logMessage(message) { // Check for a console object var console = window['console']; // Log a message if a log property is available //--------------------------------------------- if (console && console.log) { console.log(message); } } dojo.ready(init); </script> </head> <body class="claro"> <div id="map" style="width:1024px; height:512px; border:1px solid #000;"></div> </body> </html>**EDIT**This is not associated with there being a symbol or a renderer on a graphics layer to which the info window points. I was able to reproduce this problem in a separate application that has both symbols and renderers. The map infoWindow's coords property is always undefined. What am I doing wrong?
