origData = r'C:\Documents and Settings\whitley-wayne\Desktop\pointsToPolySerysian2\orig\Reach1B.shp' import arcpy arcpy.env.workspace = r'C:\Documents and Settings\whitley-wayne\Desktop\stage.gdb' arcpy.env.outputCoordinateSystem = origData arcpy.env.overwriteOutput = True # Copy Features # http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//001700000035000000 arcpy.CopyFeatures_management(origData, 'Reach1B_lines') # Create Routes # http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//003m00000005000000.htm #CreateRoutes_lr (in_line_features, route_id_field, out_feature_class, measure_source, {from_measure_field}, {to_measure_field}, {coordinate_priority}, {measure_factor}, {measure_offset}, {ignore_gaps}, {build_index}) arcpy.CreateRoutes_lr('Reach1B_lines', 'ProfileM', 'Reach1B_routes', 'TWO_FIELDS', 'OID_', 'Shape_Leng') fields = ['LeftBank_ft', 'RightBank_ft'] # Add Field # http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//001700000047000000 # AddField_management (in_table, field_name, field_type, {field_precision}, {field_scale}, {field_length}, {field_alias}, {field_is_nullable}, {field_is_required}, {field_domain}) for field in fields: arcpy.AddField_management('Reach1B_lines', field, 'DOUBLE') # Calculate Field # http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00170000004m000000 # CalculateField_management (in_table, field, expression, {expression_type}, {code_block}) for field in fields: exp = '!' + field.split('_')[0] + '!*!Shape_Leng!' arcpy.CalculateField_management('Reach1B_lines', field, exp, 'PYTHON') # Copy Rows # http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//0017000000n4000000 # CopyRows_management (in_rows, out_table, {config_keyword}) arcpy.CopyRows_management('Reach1B_lines', 'in_table') # Make Route Event Layer # http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Make_Route_Event_Layer/003m00000008000000/ # MakeRouteEventLayer_lr (in_routes, route_id_field, in_table, in_event_properties, out_layer, {offset_field}, {add_error_field}, {add_angle_field}, {angle_type}, {complement_angle}, {offset_direction}, {point_event_type}) in_event_properties = 'ProfileM POINT LeftBank_ft' arcpy.MakeRouteEventLayer_lr('Reach1B_routes', 'ProfileM', 'in_table', in_event_properties, 'LeftBankPts') arcpy.CopyFeatures_management('LeftBankPts', 'LeftBankPoints') in_event_properties = 'ProfileM POINT RightBank_ft' arcpy.MakeRouteEventLayer_lr('Reach1B_routes', 'ProfileM', 'in_table', in_event_properties, 'RightBankPts') arcpy.CopyFeatures_management('RightBankPts', 'RightBankPoints') # ...the channel poly building component: # Array # http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Array/000v0000005r000000/ polyArray = arcpy.Array() inputPts = 'LeftBankPoints' # SearchCursor (dataset, {where_clause}, {spatial_reference}, {fields}, {sort_fields}) # http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//000v00000039000000 rows = arcpy.SearchCursor(inputPts, '', '', '', 'ProfileM A') for row in rows: pnt = row.Shape.getPart() polyArray.add(pnt) inputPts = 'RightBankPoints' rows = arcpy.SearchCursor(inputPts, '', '', '', 'ProfileM D') for row in rows: pnt = row.Shape.getPart() polyArray.add(pnt) # Polygon # http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//000v000000n1000000 polygon = arcpy.Polygon(polyArray) arcpy.CopyFeatures_management(polygon, 'channel') # ...the first/last point extraction from lines, outer poly building component: polyArray.removeAll() inputLns = 'Reach1B_lines' # Polyline # http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Polyline/000v000000n2000000/ rows = arcpy.SearchCursor(inputLns, '', '', '', 'ProfileM A') for row in rows: pnt = row.Shape.firstPoint polyArray.add(pnt) rows = arcpy.SearchCursor(inputLns, '', '', '', 'ProfileM D') for row in rows: pnt = row.Shape.lastPoint polyArray.add(pnt) polygon = arcpy.Polygon(polyArray) arcpy.CopyFeatures_management(polygon, 'outer_poly') # ...the check for change in n-vals: rows = arcpy.SearchCursor(inputLns, '', '', '', 'ProfileM A') row = rows.next() Nleft = row.Leftbank_N Nchan = row.channel_N2 Nrght = row.rightbank_ row = rows.next() # list to break polys breakList = [] while row: if row.Leftbank_N != Nleft or row.channel_N2 != Nchan or row.rightbank_ != Nrght: breakList.append(row.ProfileM) Nleft = row.Leftbank_N Nchan = row.channel_N2 Nrght = row.rightbank_ row = rows.next() del row, rows # form feature layer where_clause where_clause = '(' for each in breakList: where_clause = where_clause + str(each) + ', ' # AddFieldDelimiters # http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//000v0000004n000000 # AddFieldDelimiters (datasource, field) where_clause = arcpy.AddFieldDelimiters(inputLns, 'ProfileM') + ' IN ' + where_clause[0:-2] + ')' # MakeFeatureLayer_management (in_features, out_layer, {where_clause}, {workspace}, {field_info}) arcpy.MakeFeatureLayer_management(inputLns, 'changeN', where_clause) arcpy.CopyFeatures_management('changeN','breakLines') # FeatureToPolygon_management (in_features, out_feature_class, {cluster_tolerance}, {attributes}, {label_features}) inFeatures = ['breakLines','channel','outer_poly'] arcpy.FeatureToPolygon_management(inFeatures,'break_polys')
>>> import arcpy >>> arcpy.env.workspace = r'C:\Documents and Settings\whitley-wayne\Desktop\pointsToPolySerysian\Reach1_Banks' >>> polyArray = arcpy.Array() >>> where_clause = '"FID" > 1131 AND "FID" < 1148' >>> inputPts = "Reach1_Banks.shp" >>> pointsLeft = [] >>> pointsRight = [] >>> points = [] >>> rows = arcpy.SearchCursor(inputPts, where_clause) >>> for row in rows: pnt = row.Shape.getPart() points.append(pnt) >>> for i in range(0,len(points)-1,2): pointsLeft.append(points) pointsRight.append(points[i+1]) >>> len(pointsRight) 8 >>> pointsRight2 = [] >>> for i in range(len(pointsRight)-1,-1,-1): pointsRight2.append(pointsRight) >>> len(pointsRight2) 8 >>> for eachPoint in pointsRight2: pointsLeft.append(eachPoint) >>> len(pointsLeft) 16 >>> cur = arcpy.InsertCursor("testPolys.shp") >>> feat = cur.newRow() >>> for eachPoint in pointsLeft: polyArray.add(eachPoint) >>> feat.Shape = polyArray >>> cur.insertRow(feat) >>> del cur >>>
# these are point objects (no longer text) points = [point1, point2, point3, point4, point5, point6] array = arcpy.Array() for point in points: array.add(point) # close the poly array.add(points[0]) # load the array into geometry object polygon = arcpy.Polygon(array) # Here, you'll probably want an insertcursor to loop and load geometry for multiple features... # But for demo on a single feature, you can use copy features: arcpy.CopyFeatures_management(polygon, r'C:\JustTesting.shp')
# For example say instead of the string list shown, the following is a python list of point objects: >>> points = ['point1', 'point2', 'point3', 'point4', 'point5', 'point6'] # Define 2 new lists to load for left and right sides: >>> pointsLeft = [] >>> pointsRight = [] Now you need a looping mechanism to load the empty lists: >>> for i in range(0,len(points)-1,2): pointsLeft.append(points) pointsRight.append(points[i+1]) # Now the lists are 'segregated' odd and even: >>> print pointsLeft ['point1', 'point3', 'point5'] >>> print pointsRight ['point2', 'point4', 'point6'] # Reverse the order, say on the right, to set up 'connecting' the 2 lines: >>> pointsRight.sort(reverse=True) >>> print pointsRight ['point6', 'point4', 'point2'] # Now the list can be 'mashed' together: >>> for eachPoint in pointsRight: pointsLeft.append(eachPoint) # Still called 'pointsLeft', but it's really a sequence around both sides... >>> print pointsLeft ['point1', 'point3', 'point5', 'point6', 'point4', 'point2'] >>>
