Hi i am trying to add muliple picture marker symbol in my app where x and y coordinates of different type of markers come from db like low signal and high signal
Now i am trying to add it in my map like below but it doesn't show up with markers
import QtQuick 2.7
import QtQuick.Controls 2.1
import QtQuick.Controls.Material 2.1
import QtQuick.XmlListModel 2.0
import ArcGIS.AppFramework 1.0
import Esri.ArcGISRuntime 100.2
Item { //! [GOSymbols MapView]
// Map view UI presentation at top
MapView { id: mapView
anchors.fill: parent
rotationByPinchingEnabled: true
zoomByPinchingEnabled: true
Map { BasemapOceans {} initialViewpoint: viewPoint
GraphicsOverlay { id: graphicsOverlay
GraphicsOverlay{ id:markergraphicOverlay
} //! [GOSymbols MapView]
// the center of the mapview
ViewpointCenter { id: viewPoint
center: Point { x: 172.49307355493
y: -43.4810759934974
spatialReference: SpatialReference { wkid: 4326
targetScale: 288895.277144
PictureMarkerSymbol { id:markersymbol
url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Recreation/FeatureServer/0/images/e82f744ebb069bb35b234b3fea46deae"
width: 38.0
height: 45.0
offsetX: 0
offsetY: 25
SimpleFillSymbol { id: fillSymbol
style: Enums.SimpleFillSymbolStyleSolid
color: Qt.rgba(1, 1, 0, 0.4)
SimpleLineSymbol { style: Enums.SimpleLineSymbolStyleSolid
color: "blue"
width: 2.0
antiAlias: true
//! [GOSymbol line symbol]
// add all the graphics to the graphics overlay
// create each graphic type and then add them to the overlay at a time
// alternatively you can create all of them and store in a list and add all of them
// by calling appendAll and pass in the list.
Component.onCompleted: { // add boat route
graphicsOverlay.graphics.append(createGraphic(createBoundaryRoute(), fillSymbol));
markergraphicOverlay.graphics.append(createGraphic(addMarker(), markersymbol));
// add the nesting ground
//! [GOSymbol createGraphic]
// create and return a graphic
function createGraphic(geometry, symbol) { var graphic = ArcGISRuntimeEnvironment.createObject("Graphic"); graphic.geometry = geometry;
graphic.symbol = symbol;
console.log((graphic.geometry.json));
return graphic;
//! [GOSymbol createBoatRoute]
// create the boat route
function createBoundaryRoute() { // create polyline using json
return ArcGISRuntimeEnvironment.createObject("Polygon", {"json": boundaryJson}); }
function addMarker(){ return ArcGISRuntimeEnvironment.createObject("Point",{"x":172.49307355493,"y": -43.4810759934974, "spatialReference": { wkid: 4326 } }); }
//! [GOSymbol boatRouteJson]
property var boundaryJson : {"rings":[[[172.4864177167, -43.4807531333], [172.4947915167, -43.4814620167], [172.4942547333, -43.4809051667], [172.4937289833, -43.4799734], [172.4935005833, -43.4796536333], [172.4934417167, -43.4795711167], [172.486064, -43.4807159833], [172.4860340333, -43.4807206667], [172.4864177167, -43.4807531333]]], "spatialReference":{"wkid":4326}} //! [GOSymbol boatRouteJson]
