From the help documentation:Using the Is Null in conjunction with the Con tool, you can change NoData values on a raster to any desired value while retaining the original non-NoData values for the remaining cells.---To change NoData value to 0, you can simply use the raster calculator with following statement:Con(IsNull(raster), 0, raster). [ATTACH=CONFIG]11938[/ATTACH]
outWorkspace = "D:/GIS_Watf/Output_PrepAnalysis/" inRaster = "D:/GIS_Watf/Output_wi/d074bhgo_wi" outRaster = outWorkspace + "e074bhgo" #extent is xmin ymin xmax ymax arcpy.env.extent = arcpy.Extent(-2638000, 1870000, 2210000, 5923000) # Process: Copy Raster arcpy.CopyRaster_management(inRaster, outRaster, "", "", "", "NONE", "NONE", "")
