I am trying to find a solution for a large dataset.
I have a polygon Feature Service. It has about 1000 records that consist of a boundaries of large swaths of the state. Each polygon could be 1/4 to 1/2 the size of the state. Each polygon in the FC is made up of many counties which are then dissolved into a single geometries.
To even render these polygons at one time in AGOL is almost laughable.
But I still need to find a way to enter an address or do a map click that drills down into this layer and returns information on the many polygons that is will locate.
Does anyone know how to NOT render the features in AGOL but still run a query against the Feature Service in AGOL. It then needs to return a list with information, AND also be able to click on the results to highlight that locations boundary.
I would like to use the Query Widget and return a list and be able to highlight the record clicked on in the list...BUT I think the only way to get this to work is to render the geometries in the map...which will not happen do to their size and complexity.
How does the GP Tool Widget work....Can I set it up to allow a user to click on the map and pass the GP Tool an XY and then handle the selection on the server side and return a list. But then I would have to call the Server side again if I click the list to show its geometry????
