Just wondering if it's possible to adjust this script for my own use. Sort of a python newb here, so any guidence you have would be most appreciated. I am trying to convert a TIN from a Microstation .dgn file to an esri TIN that I could use in ArcScene. I have entered in the correct file path for my .dgn and the output location where I want the TIN, but after running the script, I only have a blank .txt log file.
Do I need to adjust any of the other variables? Also, I am running this from IDLE. Do I need to run it as a tool in ArcMap to specify any of the parameters?
Any insight you might have on converting a .dgn to a TIN is much appreciated.
Thanks!
Andy
is there any way to do this process without using Python script. I have ArcMap 10 with 3D and Spatial Analyst tools. I have imported a 3D dgn file into my map and need to create a TIN raster. Im new to all this so sorry if this isn't an appropriate place to ask this question, and thanks in advance for any help.
