<StackPanel VerticalAlignment="Top" HorizontalAlignment="Center"> <RadioButton x:Name="Rb" Content="Test" Tag="{Binding ElementName=MyMap}" Click="RadioButton_Click"/> <RadioButton x:Name="Rb2" Content="Test" Tag="{Binding ElementName=MyMap2}" Click="RadioButton_Click"/> </StackPanel>
private void RadioButton_Click(object sender, RoutedEventArgs e) { var rb = sender as RadioButton; if (rb.IsChecked.HasValue && rb.IsChecked.Value) MyLegend.Map = rb.Tag as Map; }
i tried your solution but it didnt work.i want when i click in the radiobutton of map1....the map1 appear..and if i want the map2..i click in the other radiobutton.
i mean when i click on the radiobutton of "map1", the map1 appear ine the screen with his legend, and when i click on radiobutton of map2, the map2 appear with his legend.i wish i explained well what i want !!
<Grid x:Name="LayoutRoot" Background="White"> <esri:Map x:Name="Map1" Extent="-20037507.0671618,-20037507.0671618,20037507.0671618,20037507.0671619"> <esri:ArcGISTiledMapServiceLayer ID="basemap" DisplayName="Base Map 1" Url="http://services.arcgisonline.com/arcgis/rest/services/world_topo_map/MapServer" /> <esri:FeatureLayer ID="points" DisplayName="Incident Points" Url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/operations/FeatureServer/0" DisableClientCaching="True"/> </esri:Map> <esri:Map x:Name="Map2" Extent="-20037507.0671618,-20037507.0671618,20037507.0671618,20037507.0671619" Visibility="Collapsed"> <esri:ArcGISTiledMapServiceLayer ID="basemap" DisplayName="Base Map 2" Url="http://services.arcgisonline.com/arcgis/rest/services/world_topo_map/MapServer" /> <esri:FeatureLayer ID="lines" DisplayName="Incident Lines" Url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/operations/FeatureServer/1" DisableClientCaching="True"/> <esri:FeatureLayer ID="polygons" DisplayName="Incident Polygons" Url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/HomelandSecurity/operations/FeatureServer/2" DisableClientCaching="True"/> </esri:Map> <Grid VerticalAlignment="Bottom" HorizontalAlignment="Right"> <esri:Legend x:Name="Legend1" Map="{Binding ElementName=Map1}" LayerIDs="points" /> <esri:Legend x:Name="Legend2" Map="{Binding ElementName=Map2}" LayerIDs="lines,polygons" Visibility="Collapsed" /> </Grid> <StackPanel VerticalAlignment="Top" HorizontalAlignment="Right" Margin="10"> <RadioButton GroupName="MapSwitcher" Tag="1" Content="Display Map 1" IsChecked="True" Click="RadioButton_Click" /> <RadioButton GroupName="MapSwitcher" Tag="2" Content="Display Map 2" IsChecked="False" Click="RadioButton_Click" /> </StackPanel> </Grid>
private void RadioButton_Click(object sender, RoutedEventArgs e) { string tag = (sender as RadioButton).Tag as string; switch (tag) { case "1": Map1.Visibility = Visibility.Visible; Legend1.Visibility = Visibility.Visible; Map2.Visibility = Visibility.Collapsed; Legend2.Visibility = Visibility.Collapsed; break; case "2": Map2.Visibility = Visibility.Visible; Legend2.Visibility = Visibility.Visible; Map1.Visibility = Visibility.Collapsed; Legend1.Visibility = Visibility.Collapsed; break; } } }
