I’m using ARCGis Pro 2.2.2 connecting to Oracle 12.1.0.1.0 to enterprise Geodatabase 10.2 and I’m getting below error when I try to view Geodatabase connection properties .
Although I mange to connect to the geodatabase .
I don't think so as I get the same error when using SDE 10.5.1 with all applicable patches. I'm just thinking you might want to bring your SDE database up to a more current version as 10.2.x is getting dated at this point, but this is probably not a trivial task.
Is your org also using ArcMap? If so, what version are you using for ArcMap?
Micheal.
we are using SDE 10.2.2 ... , is this can cause the problem ?
What version of SDE are you using as you mention Enterprise Geodatabase 10.2?
It has been a couple months since I tested last, so I am re-testing today using Pro 2.2.2 and will let you know how it goes.
UPDATE:
Since there are multiple ways to create database connection files, I will clarify that my comments relate to database connection files created using "New Database Connection" from the context menu in Catalog pane. We have observed different behavior from connection files created using context menus in the GUI vs geoprocessing tools like Create Database Connection—Data Management toolbox | ArcGIS Desktop .
Machine information:
Behaviors:
Joshua:
What version of Pro are you using where the Easy Connect workaround is not working for you?
https://community.esri.com/message/748248-geodatabase-connection-properties-fails
In the above thread Kory Kramer states that the Easy Connect workaround does work, but I'm unsure of the version he was using in his validation. At my org the Easy Connect was tested in a sandbox environment (not a production solution) and it did solve the problem in Pro 2.2.1, but maybe the Easy Connect workaround in now broken with the patch of Pro 2.2.2.
What is misleading about the bug description is that it really isn't a TNS issue, or only a TNS issue. My organization uses OID/LDAP lookups, not TNS, and we have the same issue. Furthermore, the Easy Connect workaround doesn't work either. There is something deeper rooted than just TNS that is causing this issue, I hope Esri realizes that and isn't just focusing on TNS.
You need to open a case with tech support as the Easy Connect solution has been ESRI's workaround for this issue for quite some time. The Easy Connect workaround is not supported at my org so I am hoping that ESRI resolves this issue in the next patch or major release.
Yes, it seems the issue is still present in Pro 2.2.
I am not aware of any other solution. The East Connect seems to be the only way.
The bug link is.
BUG-000096686: Unable to access 'Geodatabase Connection Properties'..
It is in the Production plan and the work around is as posted by Asrujit
thanks Asrujit for your email.
the bug is for ArcGIS pro 2.1 , does it addressed with the latest version (2.2) ??
and for workaround I'm already using oracle easy connect string , is there any other solution ...?
Looks similar to a Bug : GeoDatabase Connection Properties Fails
[BUG-000096686: Unable to access 'Geodatabase Connection Properties' when connection is created using the Transparent Network Substrate (TNS) name for an Oracle geodatabase.]
Suggested workaround: Use an Oracle Easy Connect string while connecting to the Oracle geodatabase
