Hey
Is there anyway to capture the close event on the Popup? It's great I can easily launch the Popup, but I want to know when the user closes it. Specifically this close button:
Andrew,
In 3.x you look for the popups hide event
https://developers.arcgis.com/javascript/3/jsapi/popup-amd.html#event-hide
In 4.x
watchUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">whenTrue</SPAN><SPAN class="punctuation token">(</SPAN>view<SPAN class="punctuation token">.</SPAN>popup<SPAN class="punctuation token">,</SPAN><SPAN class="string token">'visible'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> watchUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">whenFalseOnce</SPAN><SPAN class="punctuation token">(</SPAN>view<SPAN class="punctuation token">.</SPAN>popup<SPAN class="punctuation token">,</SPAN><SPAN class="string token">'visible'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">info</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'popup has been closed'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
In 4.25 I get this warning
[esri.core.watchUtils] 🛑 DEPRECATED - Module: esri/core/watchUtils🛠️ Replacement: esri/core/reactiveUtils:gear:Version: 4.24
I have tried to use reactiveUtils but without success, the watchUtils example works ok. Here is the example that works and the other that I'm not able to get to work.
//works! watchUtils.whenTrue(view.popup,'visible', () => { watchUtils.whenFalseOnce(view.popup,'visible', () => { console.info('popup has been closed'); }) }); //doesn't work reactiveUtils.whenOnce(() => view.popup.visible).then(() => { reactiveUtils.whenOnce(() => !view.popup.visible).then(() => { console.info('how to get here?'); }) });
Made a new question for this problem:
https://community.esri.com/t5/arcgis-javascript-maps-sdk-questions/popup-capture-close-event-in-4-2x/m-p/1295262#M81291
Thanks! That's exactly what I was looking for
