ArcToolbox -> Data Management Tools -> Raster -> Raster Dataset -> Mosaic To New Raster
The real oldie and goody is merge(), which with "real" Con was removed at 10.0. (Though the rough edges of the Mosaic tool have been smoothed a bit (haha). Mosaic, being a core raster tool, is not integrated in arcpy map algebra, which is a pity.
More map-algebra friendly replacements for the old (missing) merge function include:
- CellStatistics with the "DATA" parameter, using an appropriate statistics choice in case there is overlap (For example - "MAXIMUM" or "MEAN")
CellStatistics([raster1, raster2, raster3], "MEAN", "NODATA")
- Use Con and IsNull to get the first in the list that is non-NoData
Con(^ IsNull(raster1), raster1, Con(^ IsNull(raster2), raster2))) Con(^ IsNull(raster1), raster1, Con(^ IsNull(raster2), raster2, Con(^ IsNull(raster3), raster3)))
- You can still use SOMA (this is only supported for backwards compatibility).
expr = "merge({0}".format(",".join[str(r) for r in [raster1, raster2, raster3]]) tmpras = arcpy.CreateScratchName("","","raster") outras = Raster(arcpy.gp.SingleOutputMapAlgebra_sa(expr, tmpras))
Please join me and vote this up!
ideas.arcgis.com: Bring back Spatial Analyst Merge tool
UPDATE: I have posted an arcpy map algebra implementation of the old merge() functionality.
Implementing merge() in ArcPy map algebra
Hey Guys, thanks for all your help I actually used the Extract by Attributes tool SQL query Where "Rowid" =1 in the end.
all done and looking good now
