Hi
I have added dynamic map service layer on my map and dynamic map service has 10 layers with labels. I want to set label visibility to off for some layers. Any help on this.
Regards
Mudit
Hi Mudit,
You can do this using the setVisibility method. Ex:
dynamicLayer.setVisibleLayers([0]);
Thanks Jake, I want to set visibility of labels only not the complete layer. Is there any way to switch on/off layers label only without hiding layer visibility.
You can do this if you add labels as a Label Layer,
Label Layer | ArcGIS API for JavaScript
which I did and using setvisibility(same method that Jake Skinner mentioned in his reply) had it turned off when I added the it to the map.
I needed labels to show up only for print so added it then and turned off once the print job was completed.
var labels = new LabelLayer({id: "labels", pointPriorities: 'Above-Left'});
map.addLayer(labels);
labels.addFeatureLayer(layerNursing, layerNursingLabelRenderer, "{" + labelField + "}");
labels.setVisibility(false);
and it worked fine for me.
Alternatively, could also use set min and max scale to have the label layer to be visible within a scale range, if that is something you would want.
For my labels I have a second layer with only a label, then toggle it off and on with the setVisibility as mentioned before.
