I have not used the Address Manager piece yet, but in the Network Infrastructure Editing template, there was 3 fields in the DV table. ONCREATE, ONCHANGE, MANUAL.In your case for those features which did not get an ID generated you could set the GENERATE_ID value method to MANUAL=true.Then manually go in and select the parcels without an id and run the manual button.The code to the best of my knowledge was not written for large batch operations, so you might have to do it in chunks.If you do not see the aforementioned fields in your DV table, check out the Network Infrastructure Editing template and you will see the tools and fields I am referring to.We had to do something similar at a previous job when the tools were not installed properly on a person's machine who was doing editing and these fields were left blank.
