I've application using arcgis runtime standard license uses 3D analysis , and I want to connect it to arcgis server. Should I get advanced license for arcgis server or standard.
Do you think the architecture correct and licenses?
Thank you.
What is it that your application needs to do? That will depend on what Server license you'll need, I think.
If 3D analysis is needed from the Services end, then yes, that is Server advanced.
Now, for the client end:
Are you doing 3D analysis in your Runtime app? By this i mean, is the actual analysis happening locally on the device your app is running on, using local resources such as data and geoprocessing packages? Then your app will require ArcGIS Runtime SDK Standard licensing.
I hope this helps?
