//Replace existing function in MapManager //basemap menu clicked private function basemapMenuClicked(event:AppEvent):void { var id:String = event.data as String; var configBasemaps:Array = configData.configBasemaps; var sellabel:String = configBasemaps[id].label; for (var i:Number = 0; i < configBasemaps.length; i++) { var label:String = configBasemaps.label; var lyr:Layer = map.getLayer(label); if (lyr != null) { if (configBasemaps.id == id) { lyr.visible = true; if(lyr.id == "Photography"){ this.parentApplication.fader.value = 0; lyr.alpha = 1; }else if(lyr.id == "Street Map"){ this.parentApplication.fader.value = 1; lyr.alpha = 1; } } else { if(sellabel == "Photography" && lyr.id == "Vector"){ lyr.visible = true; lyr.alpha = 1; map.reorderLayer(lyr.id,1000); } else { lyr.visible = false; } } } } } //Replace existing in ConfigManager //get basemap menu items private function getBasemapMenuItems(xmlList:XMLList):Array { var menuItems:Array = []; if (xmlList.length() > 1) { for (var i:int = 0; i < xmlList.length(); i++) { var itemLabel:String = xmlList.@label; var itemIcon:String = xmlList.@icon; var itemValue:String = i.toString(); if(itemLabel != "Vector"){ var menuItem:Object = { id: i, label: itemLabel, icon: itemIcon, value: itemValue, action: "basemap" } menuItems.push(menuItem); } } } return menuItems; } //Add or maybe replace for you to the index.mxml //Add import import com.esri.ags.layers.Layer; //Add or replace functions private function faderFade(evt:Event):void { var lyr:Layer = SiteContainer.getInstance().controller.map.getLayer("Street Map"); var lyr2:Layer = SiteContainer.getInstance().controller.map.getLayer("Photography"); var lyr3:Layer = SiteContainer.getInstance().controller.map.getLayer("Vector"); lyr.visible = true; lyr2.visible = true; lyr3.visible = true; lyr.alpha = fader.value; lyr2.alpha = (1 - fader.value); lyr3.alpha = (1 - fader.value); } private function sldrDataTipFormatter(value:Number):String { return int(value * 100) + "%"; } //Add or replace canvas <mx:Canvas width="150" right="450" top="0" height="35" styleName="WidgetCanvas"> <mx:HSlider id="fader" x="25" y="10" width="100" minimum="0" maximum="1" snapInterval="0.1" liveDragging="true" allowTrackClick="true" enabled="true" change="faderFade(event)" value="1" dataTipFormatFunction="sldrDataTipFormatter"/> <mx:Image x="7" y="10" width="20" height="20"> <mx:source>com/esri/solutions/flexviewer/assets/images/icons/i_shuttle.png</mx:source> </mx:Image> <mx:Image x="125" y="10" width="20" height="20"> <mx:source>com/esri/solutions/flexviewer/assets/images/icons/i_highway.png</mx:source> </mx:Image> </mx:Canvas>
<basemaps menu="menuMap"> <mapservice label="Photography" type="tiled" visible="false" alpha="1" icon="com/esri/solutions/flexviewer/assets/images/icons/i_shuttle.png">http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_Imagery_World_2D/MapServer</mapservice> <mapservice label="Vector" type="tiled" visible="false" alpha="1">http://server.arcgisonline.com/ArcGIS/rest/services/Reference/ESRI_BoundariesPlaces_World_2D/MapServer</mapservice> <mapservice label="Street Map" type="tiled" visible="true" alpha="1" icon="com/esri/solutions/flexviewer/assets/images/icons/i_highway.png">http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer</mapservice> </basemaps>
