Good afternoon, Does anyone know the best way to represent the temperature in an area in CityEngine? Thank you
Yes, I realize that this will be my "only" solution, I will investigate.
I'll tell you later how it went.
Thanks a lot for the help
I´m not sure but, maybe it´s a combination of:
Calculate Solar Radiation | ArcGIS for Local Government (ArcGIS Pro)
and GitHub - Esri/3d-cities-template: ArcGIS template for the 3D cities solution, including tools, scripts and apps (Web, CE…
No, CityEngine can't do these calculations currently.
Thank you for your help,
In this thesis, the files are inserted as temperature inputs and with old techniques.
My initial question is whether CityEngine calculates the temperature and the radiation in the created models. Or if I have to put input data and only makes it easier for me to analyze.
I would very much like to be able to answer this question.
Thank you
Hi Pedro
Are you from Portugal?
Here a good point to start - In portuguese - Url
Good evening,
I wanted to run in the cityengine, because if it is possible to perform
shadow changes, it could also be possible to parse this type of constect,
since I wanted to do the analysis with the modeled buildings.
If I knew about projects with this type of study, I would ask them to show
me.
Thank you so much
Pedro Oliveira
2017-11-20 12:22 GMT+00:00 Matthias Buehler <geonet@esri.com>:
GeoNet <https://community.esri.com/?et=watches.email.thread>Re: Temperature in CityEnginereply from Matthias Buehler<https://community.esri.com/people/matthiasbuehlervrbn?et=watches.email.thread>in CityEngine - View the full discussion<https://community.esri.com/message/730309-re-temperature-in-cityengine?commentID=730309&et=watches.email.thread#comment-730309>
Typically, people run this type of analysis in ArcGIS Desktop, via the GP Tools...
With the new CE functionality you can quantitatively analyze this, but I suppose you need precise values.
--> Check the 3D Analyst extention for ArcGIS.
Greets,
matt
------------------------------------------------------------------------------------------------------------------matthias buehler || ceo & co-founder || msc. arch. eth zurich ------------------------------------------------------------------------------------------------------------------vrbn AG – official esri partner || www.vrbn.io || winterthurerstrasse 53 || 8610 uster || switzerland +41 78 930 04 07 || matthias.buehler@vrbn.io || @vrbnio @mattb3d
Thanks for the answer,
Do I need to identify the changes in temperature in buildings and the rest through colors?
This is all with a source in solar radiation, and also if possible represent the "intensity" or "intensity" angle of the solar radiation. can you tell me where I can see examples or someone who can specifically help me.
how would you need to show the temperatures precisely?
btw.
I'd use an attribute and link it to the color... there's also color ramps you can use in CGA for mapping colors in a value range.
