import arcpymxd = arcpy.mapping.MapDocument("Current")df = arcpy.mapping.ListDataFrames(mxd)[0]layers = arcpy.mapping.ListLayers(mxd)myDir = 'H:/Analysis/ESRI/Sean/Help/' ##the directory where you want your lyr files placedfor layer in layers:[INDENT] layerFile = myDir + str(layer) + 'lyr' arcpy.SaveToLayerFile_management(layer, layerFile) [/INDENT]
to import arcypy, globmyImages = glob.glob('C:/YourDirectory/*.jpg') ## or whatever the extension isfor myImage in myImages:~~image = arcpy.mapping.Layer(myImage)~~imageAsLayer = image[:-3] + 'lyr' ## this cuts off the extension, and adds .lyr for the new filename~~arcpy.mapping.SaveToLayerFile_management(image, imageAsLayer)
But this is creating a new problem. All my raster data is georeferenced by TFW's and I guess that I will lose my reference if I create .lyr out of my image files...
import arcpymxd = arcpy.mapping.MapDocument("Current")df = arcpy.mapping.ListDataFrames(mxd)[0]rows = arcpy.SearchCursor('c:/yourdirectory/index.shp')fields = arcpy.ListFields('c:/yourdirectory/index.shp')for row in rows:~~for field in fields:~~~~if field.name == 'Hyperlink':~~~~~~value = row.getValue(field.name)~~~~~~value = value[:-3] + 'lyr'~~~~~~addLayer = arcpy.mapping.Layer(value)~~~~~~arcpy.mapping.AddLayer(df, addLayer, "BOTTOM")
