Is it possible to configure the quality of the pictures/photos users upload on Story Map Crowdsource?
Hi Maria,
Currently contributed photos are resampled to be 1000px on their shorter side. Are you looking for higher quality photos to be available or are you concerned about low-quality photos being uploaded and seen in your stories?
I was talking with someone last week at the Esri User Conference in San Diego who had some participants upload low-quality photos. In a future release we will consider adding a warning or even blocking participants when they try to upload a low-quality photo.
If you could share some additional information about your situation that would be helpful to us as we plan future releases. Thanks!
Owen
Thanks for the quick answer.
Actually I was wondering if I can have higher quality photos, despite the
volume to store them.
It is because we want to make a campaign to collect photos around the
country (Brazil, in the case).
The purpose is to use the photos later in web pages but also in printed
materials, so we need photos with higher resolution.
I work in the National Statistics (and Mapping) Agency and we are looking
for pictures of all the cities around the country.
Best regards,
Maria
2016-07-05 15:27 GMT-03:00 Owen Evans <geonet@esri.com>:
GeoNet <https://community.esri.com/?et=watches.email.thread>Story Map Crowdsource photos qualityreply from Owen Evans<https://community.esri.com/people/OEvans-esristaff?et=watches.email.thread>in Story Maps - View the full discussion<https://community.esri.com/message/619035?et=watches.email.thread#comment-619035>
Maria,
Great, thanks for the additional information!
Like I mentioned, there's currently no way to change this in the builder; however, you can manually adjust the resampling size by editing your story map's configuration file using a tool called the ArcGIS Online Assistant. Here's how:
The smallestSide attribute is the size (in pixels) that your contributors' images are resampled to when they are uploaded, if the smaller side is longer than the value specified. The smaller side is reduced to the value specified, and the aspect ratio is preserved. Images are not resampled if the smaller side is less than the specified size.
For example, if you set smallestSide to 2000 then a 2560x1920 image would be not be resized, but a 2304x3072 would be resized to 2000x2667.
We'll definitely consider adding this to the builder in the future and also would like to add a way for authors to easily download the photos in builder as well. Currently you'd need to download them from your Crowdsource story's feature service item page.
Owen's method of increasing the photo settings does work but if you follow it exactly, you will find the app is slower to load because the app needs to load larger photos. Another workaround is to open the AGO Assistant as described but instead of editing the primary photo, add a third photo setting that will upload a new third photo attachment to your feature service that will not be used in the app.
The crowdsource app currently resamples all photos uploaded to the app based on these settings. Because resampling photos is computationally intensive, slower computers and smartphones will crash if we attempt to resample a original size photo. Because of this, we initial load all our photos at a maximum resolution of 2000px by 2000px. Because of this, the highest resolution you will be able to get out of the app is with the above settings. If you need a higher quality photo, you will need to download and customize the application code.
You can access this photo by going to the feature service item detail page in ArcGIS Online and click the data tab. In the table, you should be able to view all the attachments listed for each feature.
Here are some samples of what you'll get:
Original Settings
http://services3.arcgis.com/dGkWQRTbdsLW3GnN/arcgis/rest/services/largePhotoTest/FeatureServer/0/1/attachments/1
Largest Side: 2000/Quality: 1/Type: PNG
http://services3.arcgis.com/dGkWQRTbdsLW3GnN/arcgis/rest/services/largePhotoTest/FeatureServer/0/5/attachments/12
Owen,
Thanks for helping me to learn how to update records via the back-end, this makes switching out low res images for higher res images extremely easy.
