I'm using MS VB 2015, and I have the Esri.ArcGISRuntime loaded as a reference.
How do I open an existing Shapefile? I just want to extract some data, but having real trouble getting started. Can't seem to find any tutorials for the simple stuff.
TIA
This is my code
Public Class Form1
Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
End Sub
Private Async Sub OpenToolStripMenuItem_Click(sender As Object, e As EventArgs) Handles OpenToolStripMenuItem.Click
Dim dialog As New OpenFileDialog()
With dialog
.Filter = "Shape|*.shp|All|*.*"
If DialogResult.OK = .ShowDialog Then
Dim myShapefileTable As Esri.ArcGISRuntime.Data.ShapefileTable = Await myShapefileTable.OpenAsync(dialog.FileName)
End If
End With
End Sub
End Class
but I get warning "BC42025 Access of shared member, constant member, enum member or nested type through an instance; qualifying expression will not be evaluated."
