I am also trying to make sense of the density tools. Here are my settings. Spatial units = meters. Output cell size = 1000m, Neighborhood is circle of 50,000m, Area Units = Square Kilometers. The numbers in the output seem very low ranging from 0.2-7.2. The file consists of over 400,000 points. Are these values # of points/km2 within each neighborhood centered on analysis cell?For example, if 2000 points occur in the neighborhood then for the output cell (or analysis cell) the value of that cell will be # of points/neighborhood area(in area units defined here as square Km) or 2000/7853980 Km2 = 0.0002546 pts/km2? Is that correct?
I am having trouble myself with point density. I have a shapefile of 45000 points spread across the city of Seattle. I want to create a density map of these points. Everytime I try to use the point density tool though, it fails. Advice?David
erice-esristaff the image upload is corrupt and does not load, it's cut off part way through.
