import arcpy from arcpy import env env.overwriteOutput = 1 env.workspace = r"C:\temp\data.gdb" table = "Meters" fields = ["METER_NUMBER"] list = [] rows = arcpy.SearchCursor(table) for row in rows: list.append(row.METER_NUMBER) del row, rows #remove duplicates from list list = dict.fromkeys(list) list = list.keys() for n in list: arcpy.TableSelect_analysis(table, r"in_memory\table_sel", "METER_NUMBER = " + str(n)) #get TWACs_Number value for row in arcpy.SearchCursor(r"in_memory\table_sel"): TWACs_Number = row.getValue("TWACs_Number") out_graph_name = n out_graph_pdf = r"C:\Temp" + "\\" + str(n) + ".pdf" input_template = r"C:\Temp\KW Demand.grf" input_data = r"in_memory\table_sel" # Create the graph graph = arcpy.Graph() # Add a vertical bar series to the graph graph.addSeriesBarVertical(input_data, "KW_DEMAND") # Specify the title of the left axis graph.graphAxis[0].title = "KW Demand" # Specify the title of the bottom axis graph.graphAxis[2].title = "Meter Number" # Specify the title of the Graph graph.graphPropsGeneral.title = TWACs_Number # Output a graph, which is created in-memory arcpy.MakeGraph_management(input_template, graph, out_graph_name) # Save the graph as a PDF arcpy.SaveGraph_management(out_graph_name, out_graph_pdf, "MAINTAIN_ASPECT_RATIO", 600, 375)
Chris,I believe I was assisting your before. I think the title of the axis's being lowercase is a bug. I was able to reproduce this same behavior. I would recommend following up with Tech Support.As for the title, you can use the 'getValue' method to retrieve the value of your field. Ex:import arcpy from arcpy import env env.overwriteOutput = 1 env.workspace = r"C:\temp\data.gdb" table = "Meters" fields = ["METER_NUMBER"] list = [] rows = arcpy.SearchCursor(table) for row in rows: list.append(row.METER_NUMBER) del row, rows #remove duplicates from list list = dict.fromkeys(list) list = list.keys() for n in list: arcpy.TableSelect_analysis(table, r"in_memory\table_sel", "METER_NUMBER = " + str(n)) #get TWACs_Number value for row in arcpy.SearchCursor(r"in_memory\table_sel"): TWACs_Number = row.getValue("TWACs_Number") out_graph_name = n out_graph_pdf = r"C:\Temp" + "\\" + str(n) + ".pdf" input_template = r"C:\Temp\KW Demand.grf" input_data = r"in_memory\table_sel" # Create the graph graph = arcpy.Graph() # Add a vertical bar series to the graph graph.addSeriesBarVertical(input_data, "KW_DEMAND") # Specify the title of the left axis graph.graphAxis[0].title = "KW Demand" # Specify the title of the bottom axis graph.graphAxis[2].title = "Meter Number" # Specify the title of the Graph graph.graphPropsGeneral.title = TWACs_Number # Output a graph, which is created in-memory arcpy.MakeGraph_management(input_template, graph, out_graph_name) # Save the graph as a PDF arcpy.SaveGraph_management(out_graph_name, out_graph_pdf, "MAINTAIN_ASPECT_RATIO", 600, 375)
Just ran into the same problem and am wondering if there is a workaround?
Thanks.
Fred
